Timing belt cover
Old Feb 17, 2006 | 06:12 PM
lblackneon's Avatar
lblackneon
Default Timing belt cover
Are there any aftermarket timing belt covers that look better than stock out there. It would be nice if there was one out there that has an opening around the cam gear so I can make repeated adjustments to the cam gear.
Thanks.
Old Feb 18, 2006 | 12:19 AM
leadspud's Avatar
leadspud
Default RE: Timing belt cover
I just took a big hole saw and cut mine out, so I could get to my cam gear.
Old Feb 18, 2006 | 01:38 AM
lblackneon's Avatar
lblackneon
Good idea. What year Neon do you have? The reason I was asking was b/c it looks so tight around my cam gear area. Is it hard for you to access that area so you can adjust the timing?
Old Feb 18, 2006 | 12:08 PM
leadspud's Avatar
leadspud
Mine is a 2000. It is still not easy but you can make it work.
Old Feb 21, 2006 | 01:33 PM
lblackneon's Avatar
lblackneon
Where can u find a stock timing belt cover from. I recently noticed that mine is cracked. I'll probably modify that one.
Old Feb 21, 2006 | 03:24 PM
casper's Avatar
casper
I have not seen any aftermarket ones. You could modify a stock one though.
Old Feb 22, 2006 | 11:04 PM
lblackneon's Avatar
lblackneon
I called the Dodge dealership today and they said they have a bottom timing belt cover and two top timing belt covers. I thought there was just one timing belt cover but I was wrong. My goal is to just purchase the cover that goes right over the cam gear so I can customize it for repeated adjustments of the cam gear. Would I need to purchase the top timing belt cover? Also as far as the top timing belt covers, would I need to purchase both of them or what?
Old Feb 23, 2006 | 10:11 PM
Customlimitz863's Avatar
Customlimitz863
ORIGINAL: lblackneon
WOW. I ONLY THOUGHT THERE WAS ONE TOO.... HEY IF YOU COULD PLEASE LET ME KNOW EXACTLY HOW YOU CUST. THAT COVER RIGHT OVER THE CAM GEAR... PICS IF POSSIBLE... SOON TO HAVE A AEM GEAR.. SO I'D BE FOLLOWING YOUR STEPS....THANX ALOT...GOOD LUCK
Old Feb 24, 2006 | 01:27 AM
casper's Avatar
casper
I would suggest going to a junk yard for them, the dealer is gonna bend you over on them. You can proballly get them from the JY for $10-$20.
Old Feb 24, 2006 | 01:41 AM
leadspud's Avatar
leadspud
I think I used a hole saw big enough to see the cam gear marks and get to the nut's. It only took a few min to do, when I put the cam gear in and timing belt in. My wife has the car at work or I would go measure it and tell you what size it was. I think it was about 4"
