View Poll Results: A poll
Indy Intake Manifold
37.50%
Magnum cylinder head
62.50%
Voters: 8. You may not vote on this poll
Indy Intake Manifold or Magnum Cylinder head
Old Mar 3, 2006 | 09:35 PM
lblackneon's Avatar
lblackneon
Default Indy Intake Manifold or Magnum Cylinder head
I'm really close to buying the Indy intake manifold but then I saw a place that has the Magnum Cylinder head brand new that comes from the 01-03' Neon ACR and R/T. Since I'm about to have someone install my Cam 12, valve springs, Fidanza cam gear, would it be better for me to get the cylinder head or Indy as far as a hp increase and overall performance increaase?
>Will the Magnum cylinder head fit my SOHC 2000 Dodge Neon ES?
>Will I have to make any modifications to it?
>How is the Magnum cylinder head better?
>Does it just flow better, is it made out of a better material?
Thanks.
Old Mar 4, 2006 | 02:35 AM
BDM's Avatar
BDM
Default RE: Indy Intake Manifold or Magnum Cylinder head
Is there a difference in performance gains from the two intake manifolds?
Old Mar 4, 2006 | 04:58 AM
lblackneon's Avatar
lblackneon
Since I have a regular Neon with the plastic manifold, yes there is a difference. The Indy flows better.
Old Mar 4, 2006 | 05:51 AM
BDM's Avatar
BDM
I'm sorry I misunderstood you. I thought you were comparing the INDY and the R/T intake manifold. Now I see your are comparing HP gains from an INDY intake manifold to an R/T cylinder head...by bad.
Anyone have a before and after dyno of the INDY on a 2nd gen?
Old Mar 4, 2006 | 02:26 PM
lblackneon's Avatar
lblackneon
Based on my mods, which should be my next move?
Old Mar 4, 2006 | 03:38 PM
spudsterier's Avatar
spudsterier
if you have ever seen a mopar now magazine, i have one that has an article on the intake manifold, as well as step by step instructions on how to install it. it also shows dyno pulls from before and after...the car they tested it on had an a/fx pcm, a/fx header, better cams, and a few other goodies, that they dont explain...the gain was about 26 h.p. at the wheels...the more you have done to the car the more power it will add.
Old Mar 4, 2006 | 04:41 PM
casper's Avatar
casper
I would go with the magnum head. Its gonna be easier to do the head while you are doing the cam and valve springs. the Indy is just a bolt on, it would be easier to do later.
Old Mar 4, 2006 | 05:14 PM
lblackneon's Avatar
lblackneon
ORIGINAL: spudsterier
Which intake manifold the Indy? Was this particular Neon a magnum? Was it a 2nd Gen. SOHC or a 1st Gen. DOHC or 1st Gen SOHC?
If I get the magnum cylinder head, I'll have to get a header that fits the magnum to go on my car. I don't think my pacesetter will fit. I'm not sure but I think I'll have to get an intake manifold that fits the magnum too b/c the porting pattern is different on the exhaust and intake.
If I get the Indy, I want to be able to keep it on the car in the future even if I decide I want to add a magnum head.
Old Mar 4, 2006 | 07:01 PM
Customlimitz863's Avatar
Customlimitz863
ORIGINAL: casper
... just askin.... lord knows you know more in your pinky then ill prob ever know... but didnt the indy have fitment issues.....im just curious myself.. cus i was considering a indy.. but think ill stick to the plastic til i get turbo'ed..... n e thought on porting out the plastic manifold to match a 60mmtb.. or atleast as much as i can open it up....?
Old Mar 4, 2006 | 08:25 PM
lblackneon's Avatar
lblackneon
I've heard a few different things. I've heard people say that it has fitment issues and less people say it's fine; I'm willing to try. I have good mechanics so I'm sure he can make it work.
