duel fricton clutch?
Old Apr 16, 2006 | 03:00 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default duel fricton clutch?
i am looking at clutches for the final part of my turbo setup, what is a good clutch to run and what should i look at, i have herd the the duel friction is a great clutch and is good for the street and that is what i am looking for but if anyone has any info about it let me know but as of now i am going to do a duel friction but let me know what every one else is putting in there turboed neon? i ahve almost everything in line for the kit but i think that this is one of the last things to worry about getting........
thanks alot
Old Apr 16, 2006 | 04:08 PM
RadarLove's Avatar
RadarLove
Default RE: duel fricton clutch?
Aftermarket clutches will publish their torque ratings. As long as it's more than your car is putting out, you should be fine. No sense getting an on/off switch if you don't really need the extra gripping power, or spend extra money when you don't need to... Every manufacturer has had someone that has had problems. Centerforce tends to have more, Spec tends to have less. Proper installation (use of torque wrench) usually means fewer worries.
Best of luck!
