head rebuilt
Old Apr 18, 2006 | 12:51 AM
spikeymikey87's Avatar
spikeymikey87
Default head rebuilt
how much power do u guys think i will get with a new head port&polished with crane 10 or maybe 12 cam and crane valves and springs?
Old Apr 18, 2006 | 01:28 AM
03neonRT's Avatar
03neonRT
Default RE: head rebuilt
ORIGINAL: spikeymikey87
Well if your going for something like that you might as well go for the crane 12 or maybe the crane 14 (i've heard the crane 14 makes power past our 6750 Rev limit, just like the magnum cam does, so with NGC you wont get as much out of it)...as for total whp gains you'll probably be looking at...oh maybe 15-20?
Old Apr 18, 2006 | 10:23 AM
RadarLove's Avatar
RadarLove
You'd get more from swapping in a stock Magnum head (and exhaust manifold...). Those have been flow tested to outflow the older DOHC heads, even with serious p/p work (the newer non-turbo PT head was marginally better for some reason). HP gains from a stock Magnum head (and cam), along with the intake and exhaust manifolds, plus the 2.25" stock Magnum piping and muffler will get you pretty close to the Magnum's 150 HP rating, which is a good 20+ HP gain. The p/p work to get a regular SOHC head to that level is going to cost 3-4 times what a used Magnum head would...
The stock Magnum springs seem to be more reliable than the Crane offerings, just so you're aware. Tons cheaper too...
The Crane 14 or bigger on stock compression is going to have idle issues. I'd stick with the Crane 12, the stock 2001 Magnum cam, or the ZEX/Comp Cams 400 grind.
Best of luck!
