problem with camber with a drop
Old May 4, 2006 | 06:45 PM
spikeymikey87's Avatar
spikeymikey87
Default problem with camber with a drop
has anyone that lowered their car have a problem with excessive negative camber?
Old May 4, 2006 | 09:42 PM
spudsterier's Avatar
spudsterier
Default RE: problem with camber with a drop
if you have the stock struts then you might have to file out the holes to fix that
Old May 4, 2006 | 10:53 PM
ewetho's Avatar
ewetho
From a stock strut you can either elongate the bottom or top holes to allow the sterring knuckle to be properly positioned for camber. Or you can get adjustable camber bolts and follow instructions for installation or let your aligment guy install them for you. Basically a high tensile strength bolt that is thinner with an ofset and then has a sleeve that is also off-center provides a cam action. This allows for adjustment.
Old May 5, 2006 | 12:46 AM
spikeymikey87
well im going to get the tokico hp blues so would that be any different?
