Downstream 02 sensor simulator Questions???????
Old May 19, 2006 | 12:29 PM
NHARINTON's Avatar
NHARINTON
Default RE: Downstream 02 sensor simulator Questions???????
ahhh, sorry for the caps im a dumb as*[]
Old May 19, 2006 | 01:01 PM
tooslow's Avatar
tooslow
hey did you use 2 defoulers if not the code might come back that wright up uses only one but with some pll the code comes back if this happens just screw in the second one in front of the drilled one.
Old May 19, 2006 | 01:06 PM
NHARINTON's Avatar
NHARINTON
Yeah i used two, also i just for anyone else, dont drill out the one you screw into the pipe, only the ont the o2 goes into!!!
Old Apr 4, 2008 | 10:48 AM
pcman's Avatar
pcman
Just wondering ifthe non-foulers arestill working for you car. I have removed my cat on a 2005 sxt and thinking about doing this.
thanks.
Old Apr 4, 2008 | 02:06 PM
neon03se's Avatar
neon03se
you don't HAVE to drill or use two non foulers. I just screwed the O2 sensor in one non fouler as is and its still working perfectly fine *knock on wood*
Old Apr 4, 2008 | 03:25 PM
GrApHite03's Avatar
GrApHite03
ya, if you have to drill then you bought the wrong size de-fouler... mine screwed in fine, no drilling required.
Old Apr 5, 2008 | 01:05 AM
sparky1_2007's Avatar
sparky1_2007
Do yourself a favour and get one of these: http://cgi.ebay.com/ebaymotors/CEL-F...spagenameZWDVW
it's basically what everyone's trying to make you build on your own, but id just save yourself the time and order it for $10 and $5 shipping.
It screws onto your downstream o2 sensor, then the mechanical simulator screws into the DP/Cat.
it basically restricts airflow into the o2 sensor to make it think that the exhaust gasses arent flowing too fast.
Old Apr 5, 2008 | 02:17 AM
neon03se's Avatar
neon03se
^^^why would you spend that much and wait for shipping, when you can easily go to your closest auto parts store and do it for less than that.Makes no sense
edit* that looks almost identical to the non foulers (probably are and the seller is trying to make more money). As for time, if you do it the way we are telling you to do it, it would take no more than 5 minutes plus whatever time it takes to go to the store.
Old Apr 5, 2008 | 04:53 AM
sparky1_2007
ORIGINAL: neon03se
because i was lazy at the time, and didnt feel like messing up my o2 sensor at the time :|
so i just went and got a pre-made one.
no harm no foul, just spent $10 more on something that i shouldn't have.
