Open Throttle? Good? Bad?
Old May 28, 2006 | 02:05 AM
unleashedcc's Avatar
unleashedcc
Default Open Throttle? Good? Bad?
i have heard info about running with an open throttle? anyone has sum background info about this subject? dont really know if i sound dumb for asking?
Old May 28, 2006 | 02:11 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Open Throttle? Good? Bad?
Open throttle? What do you mean. I guess I haven't heard of that before.
Old May 28, 2006 | 02:32 AM
unleashedcc
i dont know, something bout takin out the lil door inside of the TB that opens up when u give it gas, i heard its better running without it,not sure if its true, although it will get continuos air flow, dont know
Old May 28, 2006 | 02:34 AM
LowSlowNeon
That would mean your at full throttle all the time. What good would that do for you?
Old May 28, 2006 | 02:40 AM
unleashedcc
honestly dont know, i heard of it and i kinda wanted to know what ppl thought of it, im getting the 60mm soon 270$ is alot at the moment lol
Old May 28, 2006 | 02:46 AM
spikeymikey87's Avatar
spikeymikey87
thats way too big you don't really need that unless you are getting some serious mods to come but if your car was wide open throttle all of the time, you wouldnt be able to stop yourself because your tires would just keep going. where did you read about it id like to read it too
Old May 28, 2006 | 02:50 AM
unleashedcc
didnt quite read it, heard sum JDM fellas talkin bout it the other night at the races, also takin out sum sensor which is the one that tells the computer how much air to take in. Im talkin hardcore GSR all motor OBD1s type of stuff, theres a clique here in MIAMI thats is whippin even SRT4s and EVOS, so i thought it was legit
Old May 29, 2006 | 12:58 AM
spikeymikey87
maybe they are talking about the IAT sensor which is located on thhe elbow on the stock intake. they prob mean putting it in your grill so that it will think the air going into your car is colder so it opens up the injectors for a little bit longer
Old May 29, 2006 | 06:35 PM
ewetho's Avatar
ewetho
Sounds like they are mding an old Bosch throttle body which in addition to the throttle plate had spring loaded flap that measure the air flow through the engine.
Irrelevant to the Neon.
