no brake lights
no brake lights
I have no brake lights. I have blinker, park, hazard, but no brake lights. I have traced the the white and pink wire from the brake switch all the way to the ecu. At the multifunction switch I have no power. I have checked all my fuses and I am stumped. PLEASE HELP!!!! I don't want to get rearended or get a ticket.
RE: no brake lights
try replacing the stop light switch.
In order to signal a stop, a brake-pedal operated stoplight switch is provided to operate the vehicle's stop lights. Besides lighting the rear lamps, the switch also operates the center high-mounted light that became mandatory on later models. Cruise control equipped vehicles usually use a vacuum release valve. In this case, both the vacuum release valve and the stoplight switch are turned on by movement of the brake pedal.
