Drivers side carpet is wet sometimes....
Old Aug 6, 2006 | 03:46 AM
LowSlowNeon's Avatar
LowSlowNeon
Default Drivers side carpet is wet sometimes....
Okay, I have no idea what is causing this. Sometimes the carpet on the drivers side is wet. And its not caused from my wet shoes. Has anyone had this problem before? The first time it happened I drove through probably about 4-5 inches of water and noticed it the next day. Okay, so I thought it was just from that instance. Wrong....about a week later the floor was wet again after a day it hadn't rained, on top of that it was like 90 degrees out. I'm not sure what is causing it, but I guess I'll have to keep monitoring the situation. Anyone else had a similar problem?
Old Aug 6, 2006 | 04:41 AM
NHARINTON's Avatar
NHARINTON
Default RE: Drivers side carpet is wet sometimes....
Not quite sure if this will help but is your a/c on when it was happening?? Maby with the humidity out thier thier is alot of condensation????
BTW, how is gr i just moved to san diego from Spring Lake/ Muskegon. I hated that place,,, anyways good luck with the car.
Old Aug 6, 2006 | 05:29 AM
01neon01's Avatar
01neon01
yeah when i first got my car i found that there was water in the back seat and the trunk..and i live in sunny california so i souldnt figure out where the water was comming from. i dried it up but i still have no idea where it came from..did u notice the water after you washed your car?
Old Aug 6, 2006 | 12:25 PM
LowSlowNeon
ORIGINAL: NHARINTON
I don't remember if it was both times. One time it was on for sure. Gr is okay, pretty boring......I will just have to keep track of it. I suppose it could be from the A/C condensation because I do use the A/C fairly often.
Old Aug 6, 2006 | 03:29 PM
timplett's Avatar
timplett
About the water in the back seat and trunk, I had the same problem with my car and it was leaking in from the tail lights. One (relatively) easy way to figure out where a leak is:
1) Remove the carpet in the area that is wet.
2) Make sure the area is completely dry.
3) Sprinkle with baby powder or foot powder.
4) Drive through the car wash or spray with a hose for a while.
After this you should be able to easily trace the source of the leak. If you don't see anything wet, keep spraying water over the car from as many different angles as possible. Keep spraying until you find the leak or nothing leaks and you're tired of spraying, because that probably means it was a one-time thing.
The air conditioning shouldn't really be causing problems, any condensation build-up should be in the engine bay, and shouldn't be able to get into the passenger area of the car.
Old Aug 6, 2006 | 07:44 PM
jimmyk's Avatar
jimmyk
LowSlow,
I have the exact same problem, it started after I had my Amp and fog lamps installed, the wires are running through the firewall grommet used for the factory wiring harness, it my believe that is allowing enough of a gap so water can get through when it is raining.
If someone has any other ideas or comments please let us know.
Old Aug 6, 2006 | 08:23 PM
timplett's Avatar
timplett
You shouldn't really be getting a whole lot of water up on the engine side of the firewall though. The inner fender pieces should be stopping most or all of that. I really don't think you would be getting any significant amount of water in that way. Unless of course the weather stripping under the top edge of the hood is worn out and water is getting underneath the hood there and dripping down the firewall.
Old Aug 9, 2006 | 05:14 PM
2point0togo's Avatar
2point0togo
Your tail lights... as strange as that sounds, pull out your tail lights and check the rubber seal under them. I've seen many come in with that problem. Water in the trunk, rear seat and one side or the other in the front. The water collects around the tails and drains to the lowest parts inside the car... the front.
Old Aug 9, 2006 | 08:31 PM
timplett's Avatar
timplett
Yeah same thing happened to my car, just sealed them up with some Black Jack (basically tar in a caulking tube) lol
Old Aug 9, 2006 | 11:40 PM
lippint's Avatar
lippint
Don't know about cars but in my truck the drain tube for the A/C was plugged up by some bug that took up residence, this caused the condensate to end up on the floor instead of outside. When we lived in Texas the mud daubers did the same to my outboard motor water line.
