hahn racecraft
Old Aug 16, 2006 | 07:02 AM
fastloudfzr's Avatar
fastloudfzr
Default hahn racecraft
tryin to find anyone who actually has a hahn racecraft stage 2 in there 2nd gen neon. hopein to get some info and actually hp gains not what the website says. and can someone give me a link to this chill factor turbo kit and any possible feed back on that also.
Old Aug 16, 2006 | 02:49 PM
03neonRT's Avatar
03neonRT
Default RE: hahn racecraft
Chill Factory is out of business i think...as for the Hahns, its not how much the kit can put out, its how much your engine can handle. The Hahn turbo kit could easily be tuned to put out 250whp, 270wtq...but your engine will blow with those kind of numbers.
Old Aug 17, 2006 | 12:58 AM
fastloudfzr
i am aware of this but what kind of numbers can i safely run on a daily driver.
Old Aug 17, 2006 | 12:59 AM
fastloudfzr
what about the head should i change the valves cam and springs.
Old Aug 17, 2006 | 01:10 AM
04 mo neon's Avatar
04 mo neon
8psi is what I'd run, around 200whp. Same if you went nitrous, nothing more than 200 whp and you start to really wear down the internal components pretty fast.
Old Aug 17, 2006 | 01:33 AM
fastloudfzr
so what about the plastic manifold is that a problem up to just say 20 psi.
Old Aug 17, 2006 | 01:39 AM
04 mo neon's Avatar
04 mo neon
Plastic shouldn't be an issuse it would probabley take 30 psi to be quite honest as long as the seal didn't break but I would NEVER try it.
Old Aug 17, 2006 | 02:07 AM
03neonRT's Avatar
03neonRT
ORIGINAL: fastloudfzr
The top end is the least of your worries, your much more likely to fry something in the bottom end of your motor...if you have the $1,200 for a bottom end performance build kit (from MP), i would buy that first. As for a daily driver, my car is going to be a daily driver and i'm starting at 5psi becauser the SRT wastegate keeps the boost at 5psi...after a month or two, i'll buy a new boost controller and push it to 8psi or so...i wouldnt go beyond that, simply because i dont want to push my luck. But for example, 10psi on a SXT with the SRT setup gave 220whp/244wtq...now the whp is well within the safe zone, however, the wtq is very close to the popping point of the motor (it should be noted that this person has had no problems that i'm aware of on 10psi).
Old Aug 17, 2006 | 07:14 AM
fastloudfzr
so do i need the whole bottom end kit or could i just use pistons and rods?
what kind of 1/4 mile times am i lookin at with 200 hp i know it all depends on the driver but roughly?
