Difference between the 2002 2.0L and the High Output 2.0L?
Old Aug 24, 2006 | 03:54 PM
02BLACKR/t's Avatar
02BLACKR/t
Default Difference between the 2002 2.0L and the High Output 2.0L?
I was just wondering what is different engine wise between the two engines. Can the high output with stand more H.P.?
Old Aug 24, 2006 | 04:16 PM
hlfbck20's Avatar
hlfbck20
Default RE: Difference between the 2002 2.0L and the High Output 2.0L?
could be wrong but i thought the 2.0 was standard and the h/o was from thr r/t models... thing is im not sure if it is a dohc or not. but i think it was bored slightly biggre then the reg 2.0
Old Aug 24, 2006 | 04:20 PM
bebi_wilson's Avatar
bebi_wilson
The H/O or Magnum engine is the R/T engine and it had a better intake and exhaust and hotter cam. The HP difference was 132 HP at the crank for the ES and SE models and the R/T has 150 HP at the crank.
Old Aug 24, 2006 | 04:28 PM
lblackneon's Avatar
lblackneon
The RT / High output Neon also has larger exhaust ports on the head than the reg. Neons. They are SOHC.
Old Aug 24, 2006 | 07:34 PM
ratam82's Avatar
ratam82
so can u put the sohc H.O. head on a non H.O. 2.0L
Old Aug 24, 2006 | 07:49 PM
03neonRT's Avatar
03neonRT
Yes you can use the head on a standard 2.0...and to the origianl question, no the H.O will not hold more power, because it uses the same connecting rods and pistons.
Oh and the tranny has much different ratios...R/T's and ACR's have the wonderful 3.94's while the standard has the craptastic 3.55's...
Old Aug 25, 2006 | 01:14 AM
02BLACKR/t's Avatar
02BLACKR/t
Thanks for all the info! It helped me out! Also i was wondering how much H.P. will the engine hold before the bottom end would need to be rebuilt?
Old Aug 25, 2006 | 01:33 PM
03neonRT's Avatar
03neonRT
HP is not what breaks things inside the motor, torque is the force that breaks rods and shoots pistons through your block. The stock bottom end can take 250wtq before you start breaking rods and such...
Old Aug 25, 2006 | 01:59 PM
lblackneon's Avatar
lblackneon
If u use the head from the RT which has larger exhaust ports you'll also have to change the header.
