hood question
Old Aug 29, 2006 | 05:40 PM
Tenth_element's Avatar
Tenth_element
Default hood question
Anyone know if a SRT4 hood is compatible with a 2000 neon hood and if A SRT-4 hood could be made to fit my 2000 neon?
Any insight would help.
Thanks,
Old Aug 29, 2006 | 05:59 PM
03neonRT's Avatar
03neonRT
Default RE: hood question
There all interchangeable.
Old Aug 29, 2006 | 06:36 PM
Tenth_element
One other question, does anyone know where I can find or order a SRT4 hood? so far I haven't had any luck finding any
Old Aug 29, 2006 | 07:50 PM
Freerider's Avatar
Freerider
an SRT-4 hood will fit but only if you install a new nose from either a 2003+ or SRT-4. It wont look very clean with the 2003+ SXT, SE models becuase the SRT-4 nose is a bit different, and the hood has a slight point in the middle of the hood, vs the regular neons have a fairly rounded hood.
So, when you put it on, you will have a slight over-hang from the hood. I believe i can find a post with pictures. I will edit this post once i find it.
either way, you will need a new front end before you can install it.
Old Aug 29, 2006 | 09:57 PM
Tenth_element
so are they exactly the same or will I need to do extra work b/c I thought I saw a 2000-2002 neon with a SRT4 hood on it with no front end modification?!?!?
So someone le me know.
and 03neonRT could you elaborate on
ORIGINAL:03neonRT
Thanks,
Old Aug 30, 2006 | 04:09 AM
03neonRT's Avatar
03neonRT
The SRT-4 hood will fit with no problem, nothing will interfere with the hood, you dont need a different bumper or anything. I've seen several 00-02 with SRT-4 hoods, an they still had stock bumper and headlights.
Old Sep 2, 2006 | 07:49 PM
nicks2kes's Avatar
nicks2kes
yes it will fit
