electric supercharger?
Old Sep 2, 2006 | 02:56 AM
Tenth_element's Avatar
Tenth_element
Default electric supercharger?
Has anyone tried an electric supercharger, I figure it is ridiculous but I was just wondering if any one has ever used one? and if so if it adds anything performane wise or if it is just a load of crap...[>:]
Old Sep 2, 2006 | 03:23 AM
timplett's Avatar
timplett
Default RE: electric supercharger?
When they make one that can run continuous off your car battery they might be worthwhile. Seeing as the best ones now can only run for about 15 seconds off of 2 or 3 extra batteries, I think they're a ridiculous waste.
Old Sep 2, 2006 | 06:28 PM
Tenth_element
bump
Old Sep 3, 2006 | 05:50 PM
GrApHite03's Avatar
GrApHite03
Crap, absolute crap.
I run a forum and one of our members posted the following:
Last week, I had contacted a large manufacturer of Electric Superchargers via eBay. The company name was "superchargers4less", and their website is www.tempestperformance.com...
Now, I didn't pay a dime for this; I had contacted them over a period of two days asking if they would allow me to "test" the supercharger, and prove to everyone that's been sceptical about purchasing one of these setups. The only catch was that it needed to be returned, and that I had to write a review (good or bad.) So here it is.
When it first arrived, I was impressed by the packaging. I opened it up, and there it was piled under some newspaper.
As I plucked the gloss black charger from the packaging, I found enclosed in a sealed bag a 6 amp switch, a nice long piece of 14 gauge braided blue wire, and instructions with pictures.
http://www.picpile.net/ims/pic_35ZLqZS/1690.jpg
http://www.picpile.net/ims/pic_35ZLqZS/1691.jpg
http://www.picpile.net/ims/pic_35ZLqZS/1692.jpg
Now before I go any further, I guess I should explain what this is going on. The test car is my daily driver -- My 1991 Chevy Cavalier Z24. It has a rather large motor I guess, compared to what most people probably put these products on, as it is a 3.1 liter V6. The other modifications performance-wise that are currently done to the car are ported intake manifolds and an underdrive pulley. It also has a Dynomax Super Turbo muffler, but without the rest of the exhaust you can't count it much.
Alright back to the review. I didn't really have the proper equipment (i.e., a dyno or flowbench) to test this piece out with to see what kind of gains I felt. All I had to rely on during this test was seat of the pants feelings, a boost gauge, and my hand to feel the airflow from the blower.
So the install starts. First thing I notice that's going to be a huge problem is that the inlet for the intake side of the blower has some sort of weird flange on it instead of just a 3" round neck. So after thinking, I took a trip to Autozone and got some sort of weird adapter thing that I saw on the shelf. I grabbed that and some Crazy Glue and came home. After using an absurd amount of crazy glue, I got the neck adapter situated on the outlet. To make sure this wasn't just going to break off as I was driving, I also put a hefty amount of JBStick around it to help secure it to the supercharger. I let it cure for about an hour.
Essentially the the whole installation speaks for itself after that problem was solved. I hooked it up to the intake, but left the air filter off due to clearance problems. Then I just ran the wiring to a switch I used to have for my cooling fan override switch, and just ran the wiring straight to that. Postive and negative come off of the blower motor; the negative to a ground and the postive to the switch. Another positive comes off the switch to a power supply.
http://www.picpile.net/ims/pic_35ZLqZS/1693.jpg
http://www.picpile.net/ims/pic_35ZLqZS/1694.jpg
So it was all hooked up. I fired the car up. Idles the same. Seems to sound a little throatier and the throttle response seemed a lot better. But was this fact or fiction? Well, I had to make sure I wasn't just imagining things. I shut the switch off, disabling the device and letting the air move naturally. Ahh -- But avail! It must have just been my mind. Sounded and responded exactly the same with it on or off. But could this be it? Did I really just spend an hour hooking everything up just to call it quits without even taking it for a drive? Of course not! I had to see what all this hype was about that the company was claiming! So I installed the boost gauge and took her for a rip.
Initially with the switch it seemed to pick up a little better in the mid range. But again, I had to switch it to off to make sure I wasn't being deceived; and I was. Felt exactly the same. At this point I was starting to feel a little disappointed, but I knew going into this after reading a lot of rave reviews, that, well, chances are it wouldn't do a thing.
So now what... Do I return this? Do I keep it on the car for ha-ha's and get proclaimed Domestic Ricer? Do I take a baseball bat to it and tell the company that they sell a bunch of garbage? No, I will return it. With a copy of this review enclosed, and I will be posting this for informational purposes to anyone wondering about one of these propoganda piles of junk.
So to all of you that didn't feel like reading this entire compilation of words, sentences, bad punctuation, and random babble; here is the moral of the story. For the $90 you are going to spend on these magical electric superchargers, you may as well go buy a $5 oscillating fan and duct tape it to your intake tract. I can't imagine what type of restriction the Inline-Type Electric Chargers have on the intake system, but my setup was a Centrifugal-Inspired Charger and it seemed to have plenty of flow at idle.
Now I try not to get technical most of the time, but here is a constantly reiterated fact about these things. A real supercharger, runs off of a pulley driven by the engines power. No electricity involved. They spin at 50,000+ RPM's! These things probably reach no more than 3,000. If these were to spin at 50,000 RPM's, I would not want to see the carnage left in your engine when it implodes.
This particular setup was supposed to flow a whopping 250CFM, but when hooked up to a battery outside of the car, it felt like sticking your face in front of a small fan on high. Is it enough air to jam the intake tract full of air enough to produce positive pressure, even all the way to WOT? I doubt it. But then again, this was on a semi-large displacement V6, maybe if it was on a small motor like a Geo Prizm you might see .5-1 psi.
All in all this review is ended; Hopefully you enjoyed the read.
Cliffnotes:
1. The electric supercharger is nowhere worth near $90. It's just a little air pusher fan. Does absolutely nothing.
2. Hopefully I can return this thing, after the JBWeld and Glue I don't know if it will come off safely... If not, I just take a baseball bat to it and send it back.
Here is a video so you can see the REAL results of an electric supercharger!
http://videos.streetfire.net/video/6...1c38022073.htm
(link may not work for a while, it says it was being optimized when I checked.
k3v
Old Sep 3, 2006 | 11:26 PM
lblackneon's Avatar
lblackneon
Interesting[&:]. It looks like a piece of junk too.
Old Sep 4, 2006 | 03:05 AM
timplett's Avatar
timplett
I've seen some different ones, Thomas Knight I believe, which used triple electric motors and reviewed much better, but could only run for 10-15 seconds on 2 or 3 extra batteries (what I referred to in my previous post). Quite literally pointless, buy a turbo.
Old Sep 4, 2006 | 04:18 AM
Freerider's Avatar
Freerider
never believe in cheap HP. 90 bucks for a BATTERY powered supercharger. Thats like buying a jeggs performance bumper sticker and hoping for 25 hp.
Old Sep 4, 2006 | 05:14 PM
timplett's Avatar
timplett
Damn I could swear I felt the extra power with that bumper sticker... lol
Old Sep 5, 2006 | 01:52 AM
GroundControl's Avatar
GroundControl
The only bumper sticker i herd of to give you some extra HP was the NO FAT CHICKS ALOUD one... WEll as for the 20 Hp chip off ebay its also a scam.... I bought one just to see what it was... ended up cracking the thing open drilling threw 2 inches of pure plastic to fine a tiny resistor thats worth 5 ****in cents pretty funny if you ask me... After a month my check engine light came on... what an experament huh... hahah
Old Feb 4, 2007 | 05:32 PM
JackH's Avatar
JackH
That is a TMC bilge blower for boats. I own several myself. While it is a great bilge blower for $25, I don't know how it is as a supercharger.
http://www.tmcin.com/index.asp?PageA...&ProdID=56
