Car Bogging down in 1-25 MPH range
Old Sep 6, 2006 | 01:57 AM
Neon2Me's Avatar
Neon2Me
Default Car Bogging down in 1-25 MPH range
I drive a 2001 dodge neon, I have a full cold air intake high performance wires, and triple platnum plugs. I just recently went from a cold air tip to a full cold air system. And right after i did that, it started to bog downin the low rpms and speeds. Im thinking that its to much air for the engine, and i will need to replace my exhaust with aftermarket. But this happened right after i installed my full cold air. Its not a huge deal, but it doesnt have the punch it used to off the line, every now and then it wont do it, like when i first start it up, but after 5 minutes it gets noticable.
HELP!!
Old Sep 13, 2006 | 02:26 AM
das2123's Avatar
das2123
Default RE: Car Bogging down in 1-25 MPH range
ORIGINAL: Neon2Me
Thats probably your problem right there. There is a post above that explains all about it.
https://dodgeforum.com/m_199034/tm.htm
Old Sep 14, 2006 | 04:39 PM
sxt_seven's Avatar
sxt_seven
you get it tune then ask about the exhaust how you can push out
ORIGINAL: das2123
ORIGINAL: Neon2Me
