Intake
Old Oct 3, 2006 | 12:17 AM
AFMed1DRob's Avatar
AFMed1DRob
Default Intake
I have a 2002 dodge neon, 2.0 and I'm trying to install an aftermarket cold air intake.... but my throttle is mounted to the side of my stock filter box...
how can I remove it, and where can I place it: 1... so it still works, and 2... so i can install the intake??
Old Oct 3, 2006 | 12:27 AM
Izero's Avatar
Izero
Default RE: Intake
ORIGINAL: AFMed1DRob
it should go along the CAI pipe itself somewhere along the line it should bolt right on... at least thats how mine is....
Old Oct 3, 2006 | 12:30 AM
AFMed1DRob's Avatar
AFMed1DRob
Default RE: Intake
CAI pipe?
Old Oct 3, 2006 | 12:37 AM
unleashedcc's Avatar
unleashedcc
Default RE: Intake
CAI is cold air intake, check out my domain i have a few shots of my CAI, might be easier seen it done than reading it
Old Oct 3, 2006 | 12:38 AM
Izero's Avatar
Izero
Default RE: Intake
yes the metal pipe that usually bends down to where you put the filter on.... sorry not sure what the technical name is.....
Old Oct 3, 2006 | 12:41 AM
hlfbck20's Avatar
hlfbck20
Default RE: Intake
Cold Air Intake tubing. thats what he is talking about. but there should be two pipes. one will go down into the fender and then there is going to be a shorter one to go from the throttle body to the intake manifold. unless you have a short ram intake then the one pipe will not go into the fender it will take the place of the stock airbox
Old Oct 3, 2006 | 12:45 AM
AFMed1DRob's Avatar
AFMed1DRob
Default RE: Intake
kool... thanks
Old Oct 3, 2006 | 12:48 AM
AFMed1DRob's Avatar
AFMed1DRob
Default RE: Intake
so, I just dismount, and re-mount my throttle to my intake piping?
Old Oct 3, 2006 | 01:00 AM
03neonRT's Avatar
03neonRT
Default RE: Intake
This should help you out...
http://www.kandn.com/instructions/69-2520.pdf
Old Oct 3, 2006 | 01:01 AM
Izero's Avatar
Izero
Default RE: Intake
no to the shorter tubing that comes with the cold air intake goes to the intake manifold and the other end goes to the throttle body, and then after that is the pipe that bends down to in the fender that hlfbck was talkin about...............
