ecu
Old Oct 8, 2006 | 04:52 PM
moobit's Avatar
moobit
Default ecu
Are all the computers for the 2nd gens interchangable. Say my car is a 00 mtx and i get a 01 mtx ecu, will that work or does it have to be the same year? thanks.
Old Oct 9, 2006 | 01:49 AM
03neonRT's Avatar
03neonRT
Default RE: ecu
As far as i know you cant interchange the 2000 with an 01-02 PCM.
Old Oct 9, 2006 | 06:35 AM
Breeze's Avatar
Breeze
Default RE: ecu
i heard you cant chip 2000's and up true right??
Old Oct 9, 2006 | 11:52 AM
slow_hemi's Avatar
slow_hemi
Default RE: ecu
from what ive heard a "chip" in a neon will not do any good and may actualy loose performance from it.
Old Oct 9, 2006 | 03:05 PM
03neonRT's Avatar
03neonRT
Default RE: ecu
Correct, no "chips" work for any 2nd Gen Neon, however, the 00-02 people have the AF/x Race PCM's and all Neons have the option of MS.
Old Oct 9, 2006 | 04:06 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: ecu
unless you have an auto ms won't work
Old Oct 9, 2006 | 08:02 PM
moobit's Avatar
moobit
Default RE: ecu
Sounds good. Its cause im having so many electrical problem. I just put in a new altenator and it seemed to work sometimes, but i still get the battery light on the cluster sometimes. Im going to try to get a new battery today. Somehow my idle is lower sometimes, like if there isnt enough power, so i have a rough idle sometimes.
Old Oct 9, 2006 | 11:41 PM
03neonRT's Avatar
03neonRT
Default RE: ecu
ORIGINAL: spikeymikey87
How do you figure this? There are several 03+ people with MS, and tons of 2nd Gen Neon owners with manual transmissions running MS.
Old Oct 10, 2006 | 12:54 PM
das2123's Avatar
das2123
Default RE: ecu
Based on what?
Old Oct 16, 2006 | 05:45 PM
JTM78's Avatar
JTM78
Default RE: ecu
So, well the MS work on automatic equiped car or not? What options do we have to up grade the ecu in the cars we all have?!
