Tachometer Clusters
Old Oct 20, 2006 | 03:48 AM
Coach's Avatar
Coach
Default Tachometer Clusters
Hey yall, as yall may or may not already know, I'm currently driving an 04 SE. The stock cluster on it only has a speedo, gas gauge, and engine heat. The dials are black. I would like to put a tachometer in the thing. Would the cluster from a SXT do the job fairly well? And also I notice that most SXT clusters have a white styling. I there a cluster with a tachometer that is a black styling like the one I already have?
Also, If I do get a used cluster from a junkyard, 'bout how much cash should I bring and exactly how difficult will it be to put in?
Thanks
Old Oct 20, 2006 | 04:10 AM
moobit's Avatar
moobit
Default RE: Tachometer Clusters
Its a plug and play cluster so it will work fine. I put one on my neon a few months back, works well. I dont know what to tell you about the color but as far as money goes, i got mine on ebay for around $80. The only problem i could think of would be that your true milage will not be shown, only the milage of the car it was taken off from. Usually people would just recommend getting one that is close enough to your true milage.
Old Oct 20, 2006 | 04:17 AM
Coach's Avatar
Coach
So you don't have to install anything extra? I would have thought that for not having a tachometer originally the car would need something else for the tachometer to work.
Old Oct 20, 2006 | 04:35 AM
camlen1098's Avatar
camlen1098
nope, all neon harnesses are pre-wired for the tach, just plug 'er in and go, the tach will work.
Old Oct 20, 2006 | 01:22 PM
SupermanNeon's Avatar
SupermanNeon
I just bought 1 yesterday at a local U-pull it for $17 plus tax..I drive a 2000 ATX without the Tach and its black...and i liked the white 1. Got it out of a car with 15,xxx miles on it..And my car is now 123,xxx I just put down on paper what my original miles were and what the miles were on the new cluster and it works fine. It was very easy to install also..Just popped up the top dash..removed the bezel in front of the cluster..and the 1 underneath the steering so i could get to the 4 screws on the cluster and then i just pulled and replaced it with the new 1..Its plug and play
Old Oct 20, 2006 | 04:33 PM
Coach's Avatar
Coach
So I'm assuming that there's no way to reprogram the odometer?
Old Oct 20, 2006 | 04:53 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Coach
No theres a way to reprogram them, its just not easy or cheap.
Old Oct 21, 2006 | 03:55 PM
LowSlowNeon's Avatar
LowSlowNeon
I've heard people say dealers can do it, and then I've also heard that they can't or will not. I would just live with it if I was you, probably not worth the trouble of reprogramming.
Old Oct 21, 2006 | 10:21 PM
srt boy's Avatar
srt boy
WITH ALL THAT BEING SAID, IS IT THE SAME TO THROW A SRT-4 CLUSTER IN A SXT?
