Has anyone had problems with the TPS sensor??? P0123
Old Nov 2, 2006 | 07:28 PM
unleashedcc's Avatar
unleashedcc
Default Has anyone had problems with the TPS sensor??? P0123
im gettin closer to findin out wuts wrong with my car, they did a whole computer check both tranni/engine. even though i had no check engine light P0123 came up
P0123 (M) Throttle Positon Sensor Voltage High Throttle position sensor input above the maximum
acceptable voltage range
aparently its the sensor at the bottom of the TB. aparently its either messed up or something is wrong with it. Has anyone had this problem? would this be why im so slow in the begining and maybe takin off in 2nd gear?
Old Nov 2, 2006 | 08:03 PM
04 mo neon's Avatar
04 mo neon
Default RE: Has anyone had problems with the TPS sensor??? P0123
That's interesting, I've taken my TB off many times because I was modeling it in CADD class and my car is slow of the line sometimes to, like a bog but not quite. your problem sounds similar to mine, I have a header and have just thought that I've lost a little low end but I could have the same problem as you.
Old Nov 2, 2006 | 09:22 PM
unleashedcc
well my car is a cow, weird thing my girl has the same car and she takes me by 2 cars so its a problem, just replaced the TPS and is still the same so im back to 0. its really slow, sometimes even dangerous. i cant switch lanes without having to floor it b4 even leavin my own lane so i can catch speed and with A/C forget it lol might as well run
Old Nov 3, 2006 | 01:31 AM
03neonRT's Avatar
03neonRT
Yes I've heard of this problem coming up before...just get the sensor replaced but on some cars they just go out for no reason...
