Vibrating Dashboard?
11-10-2006, 07:48 AM
on
All,
At different speeds, it sounds like my dashboard is vibrating (or it could be the steering wheel) Is this a common problem. The vibrating/creaking noise can last a few seconds, then stop, then start up again a bit later on. Some days it doens't do it at all
any ideas? Should I be concerned
11-10-2006, 12:12 PM
on
RE: Vibrating Dashboard?
that could be anything from a wheel that needs balenced to a bad motor mount dose the steering wheel shimmy when you brake hard.
11-10-2006, 01:00 PM
on
Quote:
ORIGINAL: fullbuilt
Mine does, should I be worried?
11-10-2006, 02:27 PM
on
no its a small prob that should be fixed by an alighnment and a balence.
11-10-2006, 08:15 PM
on
Ah, I figuered thats all I needed since I have asked around about it before, I was just getting anoter opinion.
11-10-2006, 11:52 PM
on
My dash vibrates too. If you grab the cluster trim and the dash pad and press together it goes away. Have not yet yanked it to find out why.
11-11-2006, 12:06 PM
on
your snap clips may be worn. take it off a spred them
11-12-2006, 03:42 PM
on
It seems to be worse when it is cold - Why is that?
11-12-2006, 03:44 PM
on
I have a theory that it is a very thin plastic. That is why, it vibrates in the cold. (it does atleast in the cold for me)
Mike
11-12-2006, 03:49 PM
on
I get a vibrating noise (more like a rattle) when I accelerate. STill can't figure out why.
