I NEED HELP FAST...PLEASE!!!!!
Old Jan 10, 2007 | 12:02 PM
tcosson's Avatar
tcosson
Default RE: I NEED HELP FAST...PLEASE!!!!!
I have the same problem mentioned here. I followed the cable to the steering wheel. If you take the plastic off the column you'll notice a small yellow tab sticking out from under the ignition. If I press this in the shifter will work.
Has anyone found a solution to this problem without removing the safety locks under the console. Or driving around with the plastic off the column like I'm doing.
Old Jan 10, 2007 | 03:03 PM
Izero's Avatar
Izero
you better hope a cop doesn't think you stole the car, if you ever get pulled over that is.... lol that would not be good...
Old Jan 10, 2007 | 03:50 PM
tcosson's Avatar
tcosson
Took someone to lunch today and that was the first thing they asked.
"Did you hotwire the car or something?"
Seriously though, does anyone know how to adjust this or what part I should replace to fix it?
