rotor issues
Old Dec 3, 2006 | 04:13 PM
Kaishepard0723's Avatar
Kaishepard0723
Default rotor issues
Ok so I went to replace my rear rotors of my 2003 dodge neon rt and I can't seem to get the rotor off? I think that there is a drum under the rotor, how do I get it off?[&:]
Old Dec 3, 2006 | 08:48 PM
03neonRT's Avatar
03neonRT
Default RE: rotor issues
You have to retract the brake shoes...to do this locate the rubber plug behind the rotor (it will be down and on the metal "heat shield")...there will be a star-wheel inside and you will need to use a star-wheel adjuster or just a flathead screwdriver. Turn the star-head until the shoes are retracted enough so you can take the rotors off...oh yeah, and a rubber mallet works wonders as well.
Old Dec 3, 2006 | 11:32 PM
Kaishepard0723
thank you for the post. I am going to have to try the rotor tomorrow. by the way I did buy ceramic pads 42.00 for two pairs.
