Drilled and Slotted Rotors...
Old Dec 30, 2006 | 04:06 PM
mike9fore's Avatar
mike9fore
Default Drilled and Slotted Rotors...
What do you guys think??? The Price looks pretty good...even though its from eBay...the seller also, looks pretty reputable...
http://cgi.ebay.com/ebaymotors/Dodge...63383068QQrdZ1
Thanks!
Old Dec 30, 2006 | 05:41 PM
fullbuilt's Avatar
fullbuilt
Default RE: Drilled and Slotted Rotors...
lokks decent and around normal price
Old Dec 30, 2006 | 07:44 PM
04 mo neon's Avatar
04 mo neon
I would contact the seller because their are slight difference between the years of the neon, and the srt-4, their not all the same. Also the ceramic break pad are good, but I would just buy a set at an auto parts store b/c their usually come with a lifetime gaurentee, my friend got a set for his truck and replaced them 3 time is 4 years without even a question. Last I would definatly get a set of rotor that are coated b/c they will last a heck of a lot long than uncoated.
Old Dec 30, 2006 | 08:32 PM
03neonRT's Avatar
03neonRT
They look pretty good to me, i bought mine from Cquence Motorsports on Ebay and they have been fantastic rotors. I would just go to Autozone though and buy some ceramic pads there so you can get the warranty as well.
Old Dec 31, 2006 | 01:08 PM
mike9fore's Avatar
mike9fore
Thanks Guys!!!!
Old Dec 31, 2006 | 08:59 PM
Pablodragon's Avatar
Pablodragon
ORIGINAL: fullbuilt
is that price good, including shipping? cuz it says about $43 for delivery to me, that would put them around $135 total....
Old Jan 2, 2007 | 11:04 AM
mike9fore's Avatar
mike9fore
I have been pricing them out for the past two weeks and have not found a better price for a pair!
Old Jan 2, 2007 | 10:26 PM
Izero's Avatar
Izero
about rotors..... what else do you need to do when you get cross drilled/slotted rotors? i mean i know you need to change the pads....is there anything else? and is it ok to put them on a neon with ABS? and my last question is, i was looking behind my wheels one day and i see a thick black wire that snapped from the little ring that is attached to the brake caliper.... now it is like that on all four wheels... should i fix them or just leave them? they just look like a ground of some sort b/c they are just attached to the fender well.....
Old Jan 3, 2007 | 04:00 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Izero
Nope, you dont need to do anything else besides switch both the pads and rotors at the same time. As for that black wire, it should be attached so if you can fix it i would do so, but its not really necessary.
Old Jan 5, 2007 | 02:55 AM
o2bfishn's Avatar
o2bfishn
dont rotors need to be turned or is that only after the first set of brake pads you go through? you can just slap on new rotors and pads and go?
