New Sticky??? (i need everyones input!!)
Old Jan 8, 2007 | 12:08 AM
Freerider's Avatar
Freerider
Default RE: New Sticky???
ORIGINAL: 03neonRT
I still need a good title for the thread though...needs to be bold and straight to the point for all the n00bs. .
How About:
Neon Performance Parts Review
2nd Gen Parts Information and Reviews
Old Jan 8, 2007 | 12:09 AM
03neonRT's Avatar
03neonRT
ORIGINAL: 04 mo neon
That sounds perfect, you should make it so you have levels of performance/visual mods so like easy would be cai, tint, etc...
Just make sure you really put the time into the sticky b/c if done right it could be a HUGE sucess, but if not it will just end up like the current one. BUT TO ME IT SOUNDS AWSOME!!!!!!! GO FOR IT!!!
It will start off with the basics like the format above and a picture or two per mod...then once we get the easy bolt-on performance stuff on we can go to visual mods, engine mods, and things like that. Trust me, I dont want this one to go to hell either...
So far the list will have: CAI, UDP, STS, 60mm TB, Strut Bars, Lowering Springs, MM Inserts, Booger Bushings, Cross-Drilled/Slotted Rotors w/ Ceramic Pads, and spark plug wires.
Old Jan 8, 2007 | 12:19 AM
tyler819's Avatar
tyler819
i like it, it would lower the amount of questions that everyone always asks about wat mods give you more power and so on.....
Old Jan 8, 2007 | 12:23 AM
Freerider's Avatar
Freerider
I don't know what we should do about exhaust systems... so many. Here is my vibrant review
Modification: Vibrant Dual Exhaust
Manufacturers: Vibrant.
Price Range: $269.99 - $300.00
Where to Buy: ModernPerformance, HowellAutomotive.Com, Ebay.com
Difficulty of Installation (1 as easiest 10 as most difficult): 2
Time For Installation: 1 Hour
Expected Gains (in WHP): 1-4 WHP
Explanation of Mod: Stock Exhaust Systems on neons run a full 2.25 inch tubing until the Muffler. The Vibrant exhaust replaces the stock muffler and is a full 2.25 cat back dual muffler. It simply attatches to the old stock hangers and piping.
Video:
http://smg.photobucket.com/albums/v1...antExhaust.flv
Old Jan 8, 2007 | 12:24 AM
03neonRT's Avatar
03neonRT
Modification: Lightweight Crankshaft Damper Pulley/Underdrive Pulley (UDP)
Manufacturers: MPx, Unorthodox Racing, Megan, “Ebayâ€
Price Range: $60.00-$220.00 Where to Buy: ModernPerformance.com, HowellAutomotive.Com, Ebay.com.
Difficulty of Installation (1 as easiest 10 as most difficult): 4
Time For Installation: 1 hour-2 hours
Expected Gains (in WHP): 3-5whp Explanation of Mod: The lightweight UDP is designed to reduce the amount of energy taken from the accessories and alternator. With a smaller diameter and lighter weight, the UDP reduces the loss of power accompanied with the much heavier and larger stock pulley.
Modification: Motor Mount Inserts (MM Insers)
Manufacturers: Prothane
Price Range: 25.00
Where to Buy: ModernPerformance.Com, HowellAutomotive.Com.
Difficulty of Installation (1 as easiest 10 as most difficult): 1
Time For Installation: 30 minutes- 1 hour
Expected Gains (in WHP): N/A Explanation of Mod: This modification is designed to help reduce or eliminate wheel hop. Wheel hop is a common cause for loss of traction during launch and harder motor mounts reduces wheel hop and its affects on traction.
Modification: Spark Plug Wires
Manufacturers: MSD, Magnecore, Crane.
Price Range: $40.00-$60.00 Where to Buy: ModernPerformance.com, HowellAutomotive.Com, Ebay.com.
Time For Installation: 10 minutes- 30 minutes
Expected Gains (in WHP): N/A Explanation of Mod: Aftermarket spark plug wires are designed to transfer more energy and deliver much smoother idle and acceleration. They are also a engine dress-up item.
Old Jan 8, 2007 | 12:29 AM
tyler819's Avatar
tyler819
i like it alot, it tells me everything i need to know...
Old Jan 8, 2007 | 12:32 AM
03neonRT's Avatar
03neonRT
Its been created and locked, now i just need more reviews...i figured posting each review and pictures in its own post would help reduce clutter and allow it to be more "user friendly".
Old Jan 8, 2007 | 12:44 AM
tyler819's Avatar
tyler819
can you do a review of the comp 400 camshaft andany brand ofadjustable cam gear that would be cool. By the way that info you told me worked and my CEL went off and stayed off thanks.
Old Jan 8, 2007 | 12:45 AM
Freerider's Avatar
Freerider
Modification: Ignition Coil
Manufacturers: MSD, Screamin Demon.
Price Range: $74.95-$80
Time For Installation: 10 minutes - 20 minutes
Explanation of Mod: The Stock OEM ignition coil is a good ignition coil up until you get into needing better fuel and ignition delivery. By getting a better ingition coil, you will give your spark plugs a hotter spark.
Old Jan 8, 2007 | 12:47 AM
Freerider's Avatar
Freerider
ORIGINAL: tyler819
I haven't any experience with the comp 400
but...
I will review a Crane Cam #0012, valve springs, AEM Cam Gear, and PaceSetter header after my spring break
