The Official 2nd Gen FAQ and Performance Thread
Old 09-27-2009, 04:45 PM
oberdahill's Avatar
oberdahill
oberdahill is offline
Default Torque settings
What is the torque specs for a stock intake manifold for a 2003 SXT? Removing it to clear some debris and can't find the specs for reinstallation.
  #22
Old 08-19-2010, 12:12 AM
t_k_c1982's Avatar
t_k_c1982
t_k_c1982 is offline
can i put a second generation engine in my first generation car??
  #23
Old 01-16-2011, 01:14 AM
Mark340A66's Avatar
Mark340A66
Mark340A66 is offline
Red face LSD in an 03 R/T
Hi Can I put a Quaife or QSX LDS in my 03 R/T? Thanks
  #24
Old 04-13-2011, 07:29 PM
wilb33's Avatar
wilb33
wilb33 is offline
Does anyone know how much ground clearance you will loose with OBX long tube headers?
  #25
Old 04-16-2011, 07:07 PM
Tyman01LX's Avatar
Tyman01LX
Tyman01LX is offline
well i have an 01, and while i'm online looking for exterior parts alot of sites list all parts from 2000-2005 for fitting was wondering if i changing to the 03-05 front facia and the same with taillights would work?
  #26
Old 06-19-2011, 01:30 PM
dnanout's Avatar
dnanout
dnanout is offline
Default 3400 swap
can i swap a 2.0 single cam for a 3400 gm v6 in a 00 neon
  #27
Old 05-02-2012, 06:58 PM
irishjack923's Avatar
irishjack923
irishjack923 is offline
Thank you, very helpful information.
  #28
Old 06-24-2012, 10:30 PM
mrpug68's Avatar
mrpug68
mrpug68 is offline
Default in the right place Neon project ??
I'm new to this neon thing and to this forum. Like any old gear head, we are or can be obsesive about how or what to upgrade on /in our cars. Well, here's my prblem. I don't know that much about these lil,ralleirs. I'm used to work on N/A street cars,now a new target is going to need some practical tweeks, outer bolt ons and obd2 chips. I'm also looking at this like a nooby, starting from scratch. This neon I'm driving is driven the normal go to work go to see friends kind of driveing. I've noticed the low end tq and throttle response are abit sluggish. Would working on the exhaust a good place to start or computer tricks tweeks
.My thought on the exahust better CatConv or leave the stock one,where the size of pipe inner diameter vs low end or in the rpm band and have thought about putting a long glass pack just 2ft after the cat. what are your thoughts.would running the exhaust rout straight (old school) vs bent? what are your thoughts Thanks...
  #29
Old 09-19-2012, 09:14 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Yes, you can. However, in order to make it function properly your going to need an entire wiring harness from the 2nd Gen engine. The other option is to get a standalone engine controller and leave the original 1st Gen harness in place to control basic car functions. In any case, its not worth the effort or associated cost.
Anything is possible with enough time and money.
Yes. However, its quite a bit of time and modification...or money if you have a shop do it for you.
The 2000-2002 headlights and taillights are not interchangeable with 2003-2005 front/rear fascias (and vice versa). While you can get them to "technically" fit...it doesn't look good.
I would get a good short tube header, leave the stock cat, then put in a nice cat-back exhaust. Your not going to see anything tremendous on the power front, but it will make a difference. If you go up in diameter, your going to see low end power loss, but you'll get something back up top. The place these cars really shine is handling. Do some suspension upgrades, swap out your shifter and bushings (if you have manual), throw some nice tires on there and you'll be really happy.
  #30
Old 04-24-2013, 12:55 PM
Je_fthr1's Avatar
Je_fthr1
Je_fthr1 is offline
Can I use te throttle body from a magnum for my 04 sxt or what route should I go first
Quick Reply: The Official 2nd Gen FAQ and Performance Thread
