RPM GUAGE
Old Jan 8, 2007 | 03:50 AM
2kdgneon's Avatar
2kdgneon
Default RPM GUAGE
MY 2000 NEON DOESNT HAVE AN RPM GUAGE IN IT. IS IT POSSIBLE TO GET A CLUSTER FROM ANOTHER NEON THAT HAS AN RPM IN IT AND SWAP IT INTO MINE OR SHOULD I JUST GO BUY ONE SEPRETLY?
Old Jan 8, 2007 | 04:26 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: RPM GUAGE
U could go out and buy another instrument panel (ebay is a good place for them) but u might have to wire up the gauge since its on a 2gen.
Old Jan 8, 2007 | 04:33 AM
04 mo neon's Avatar
04 mo neon
If you get a cluster whether it be srt-4 sxt or r/t with the tachometer it will work, there is one universal plug and it's a simple switch, only thing it the mileage will be different on the other gauge cluster and as far as I know and 99.9% of the people on this forum know, there is no way currently of getting it reflashed. Dealership can't do it and customer service through diamler chrysler dosn't know either. So I would still get a cluster off ebay, I got my srt-4 cluster for 60 shipped and it should just bolt up and work. Oh and if your daring you can get so led's for the cluster like me, I got some blue ones just got one less than I should have lol and I'm waiting to put mine in still.
Old Jan 8, 2007 | 02:40 PM
blocks885's Avatar
blocks885
You should order a cluster with around the same mileage as you have because of that problem..or write down what you had replace it and then keep a tally of what your mileage racks up to.
Old Jan 8, 2007 | 03:56 PM
Izero's Avatar
Izero
the only problem he might run into is a missing wire for the tach itself..... because if his car has a cluster without an RPM gauge then he might not have the RPM sensor [i dont know what its called], so yea.... that could be one slight problem... what you could also do is buy a small guage and buy yourself a pod for it, usually the gauges either come with or you can buy separatly the sensor that goes to the distributor that you can plug right up and bam there you go a nice new clean looking tach that will get some looks.... just my thought
Old Jan 8, 2007 | 09:18 PM
spikeymikey87's Avatar
spikeymikey87
nope its plug and play
Old Jan 8, 2007 | 09:57 PM
Pablodragon's Avatar
Pablodragon
there have more than a couple posts about this.... here's one of mine. my swap work plug and play easy.
I think what may be throwing some people is most all the posts before were about 03-05 Neons...
https://dodgeforum.com/m_557112/tm.htm
just to make sure we are telling him right, this plug and play swap works for the older 2000 Neon too?
Did they even have the SXT back in 2000?.. or what did they call the next step up from the ES or SE model?...did it have a tach?
Old Jan 8, 2007 | 10:32 PM
2kdgneon's Avatar
2kdgneon
SO THE SRT4 CLUSTER WILL FIT IN MY 2000 NEON?
Old Jan 9, 2007 | 01:01 AM
leadspud's Avatar
leadspud
Yes it will work. I have a SRT in my 2000. It's plug and play
Old Jan 9, 2007 | 04:30 AM
2kdgneon's Avatar
2kdgneon
WHERE COULD I BUY AN SRT4 GUAGE OR AN SXT?
