big problem help please !!!!!
Old Jan 17, 2007 | 03:51 AM
Freerider's Avatar
Freerider
Default RE: big problem help please !!!!!
Id say check all your hoses, check the clamps... also neons do have a MAP. From the sound of things...
It sounds like either a vacuum hose or the Throttle Sensor or the MAP.
Old Jan 17, 2007 | 11:37 PM
qnr69's Avatar
qnr69
when i rev it in park and its coming down from being revved it sounds like the cai is sucking up a lot of air or blowing it out is that normal on all neons?
Old Jan 18, 2007 | 12:22 AM
04 mo neon's Avatar
04 mo neon
Yes that's normal, but I agree with the idea tha it could be your TPS, what I would do is just go and buy a new throttle body off ebay. Here is one for only 25 bucks and either replace the enitre thing or take off the TPS and switch it off. But a rich fuel mixture has something to do with either a Throttle body sensor or your fuel system.
http://cgi.ebay.com/ebaymotors/2004-...spagenameZWDVW
Ends in 12 hours so bid fast!!!
Old Jan 18, 2007 | 02:02 AM
qnr69's Avatar
qnr69
ok thanx ill check it out
Old Jan 18, 2007 | 02:56 AM
04 mo neon's Avatar
04 mo neon
hurry, hurry, hurry
Old Jan 18, 2007 | 03:48 AM
qnr69's Avatar
qnr69
shooti think im just gonna order a tps at autozone which i think is the problem right?
Old Jan 18, 2007 | 03:54 AM
04 mo neon's Avatar
04 mo neon
Highly unlikly that you'll be able to do this, would just be a good idea to get a used one, but you can't say I didn't try and help you.
Old Jan 18, 2007 | 04:38 AM
qnr69's Avatar
qnr69
why wats the problem?
Old Jan 18, 2007 | 05:46 PM
qnr69's Avatar
qnr69
i think i found the problem a guy fron autozone told me the cps camshaft position sensor we will see if it works
Old Jan 18, 2007 | 05:56 PM
04 mo neon's Avatar
04 mo neon
Hopefully thats it. good luck, oh and have you changed your spark plugs in a while, a guy I know has a ford ranger and it was throwing the CPS sensor and that was cause one or two of the spark plugs were in really bad shape. just a thought
