big problem help please !!!!!
Old Jan 16, 2007 | 08:11 PM
qnr69's Avatar
qnr69
Default big problem help please !!!!!
my car was wrecked and i dont kno if it damaged any of my engine parts but it has a cai and i was driving to skool today and it starts trippin out its hard to explain but ill do my best lets see my foot was on the gas steady like usual and it felt like it was runnin out of gas i was lookin at my rpms and its usually like at 2000 2500 and it would bog down to 1000 then go back up and it would sit and bog so everytime i would give it gas it would do anything it would bog and my rpms wouldnt go up and then it steadily loses spead and i keep pressin the gas pedal and i would go just a brrrrrr then i stpped on the road and it was just sputterin barely runnin then finally died uhhh it sux.so i go and start it after skool it sputterd a bit then it ran and on the way home it did it again now my car is in the desert can someone please im thinkin mas air flow or pcm or ecu one of them comp please help me shes in a ditch haha
Old Jan 16, 2007 | 08:16 PM
j_son600's Avatar
j_son600
Default RE: big problem help please !!!!!
Dang man you are having horrible luck with the CAI thing[sm=smiley21.gif] Hope you get everything worked out.
Old Jan 16, 2007 | 08:18 PM
qnr69's Avatar
qnr69
haha ya but i think its a bad maf or maf sensor[:'(]
Old Jan 16, 2007 | 08:29 PM
j_son600's Avatar
j_son600
I'm sure someone here can help you. I have no idea where to start, my neon is the first 4cyl computer controlled car I have realy messed around with so I am new to this stuff.
Old Jan 16, 2007 | 09:27 PM
fullbuilt's Avatar
fullbuilt
if it is struggling with fuel then first cheack for water in your tank, it can have that effect
Old Jan 16, 2007 | 09:56 PM
Izero's Avatar
Izero
or a bad fuel pump... that could also be the problem, or your injectors could be clogged or it might just mean you need a tune up....
Old Jan 16, 2007 | 10:50 PM
tooslow's Avatar
tooslow
there is no maf senser in the neon. trowing any codes?
Old Jan 16, 2007 | 11:46 PM
Exubus's Avatar
Exubus
wait a minute... did you wreck your car before this happened, and have you gotten the damage fixed since the wreck? Or are you talking about today?
Old Jan 17, 2007 | 12:04 AM
qnr69's Avatar
qnr69
um my car was wrecked in like 2004 and we just got it fixed like 3 months ago but on the cai i took the accordian lookin rubber thing of then put it back on and went to drive it and it was doing that thing i described then i got a new intake which replaced the rubber accordian lookin thing it ran good then this morning it died on me and i had to walk to skool haha but after like 4 hours u try to turn it over a couple times and give gas then it will run normal but after 10 mins of driving it will die i suspect something wrong with my maf or cai since it started when i took that peice on anyone else have ideas i dont have a car it did throw a code um rich fuel mixture somerthin with air to fuel mix ratio but i reset the comp an it went of and hasnt come on since plus its only got 19000 miles but has been sitting for a while but we bought it wrecked and it has actually done this a couple times it all started when i took the peice of the maf.
Old Jan 17, 2007 | 01:51 AM
Exubus's Avatar
Exubus
hmm well I could suggest the TPS (Throttle Position Sensor), which mountson the side of the throttle body, and tells the computer how much fuel to mix depending on how far the butterfly is opened (depending on how much gas you're trying to give it). If this is not functioning it could cause some serious problems through the RPM range. If it's unplugged or there's a break in a wire, it could lean your motor out and give it only enough gas at any RPM as if your car was idling... this could cause detonation and destroy your motor very fast. Or, if it is shorted it could give a WOT signal (Wide-Open-Throttle) and shove a full-throttle fuel mixture into the air even if the car is idling. Either way, it could really mess with your engine. Your problem could be a lot of things but you might want to look there first.
