The Official 2nd Gen FAQ
#21
RE: The Official 2nd Gen FAQ
rsalgado29 this is woosh off of Cardomain Just incase you couldnt put 2 and 2 together...
Here is the standing.
If you want true control over your cars performance, there is just one thing you can do for an ECU:
MegaSquirt!!! Information can be found here on what it is and what you need:
https://dodgeforum.com/m_677291/tm.htm
And how is everything they are saying the opposite of what I said?? I said the only way to truely get anything from your cars stock ECU is to take the original ECU out of the equation for the control over Air/Fuel maps and ratios. This can be done with the megasquirt system.
As well, There are 2 BIG disputes over UDP's
Some people notice big drains from accesseries, others don't see to much of a loss (as they don't rely on them as much.).
If you plan on running a big stereo, or plan on using a lot of your accesseries a UDP is just not for you. I drive with my windows down during the summer. If your moving, your cool
Thirdly, Howell should know better than to sell the Jet chips to 03+ owners. It does nothing for performance as the ECU just voids it out.
As I WANTED to say in the cardomain post:
The ECU will void out quite a bit of the performance given to you by the minor bolt ons like the intake, the header, etc.
It is possible to make a decent amount of power, like graphite over here whom I plan to beat sometime
Another reason for a lack of performance seen from parts is that the neons come with pretty decent intake system and a great exhaust system. Its big enough, and pretty much a straight pipe until you hit the rear portion of the exhaust. So, replacing these decent working parts with better ones won't net you much. It is how much work you put into the entire system of parts that will determine how much of an increase you will see.
fourth and last, just keep working on your intake and exhaust problems. If you have questions on parts, we are more than willing to help.
Once you're done with those basics, you can then start talking about new pulley's, camshafts, cam timing, and other mods. You're ecu will make sure you are always where you should be for air/fuel
#23
ORIGINAL: neon03se
I saw an opportunity and took it. 03RT did the same thing to me a while back.
Nut hugging huh, that's clever. Good Job
Rsalgado it was a funny thats all. Boredom kicked in lol. As for modding your neon, I definetely tried that route for a bit and saw nothing but money down the tube. There are things that can make your car run better but to make it fast is gonna take a lot of money and work.
Read the FAQ in the sticky at the top, it has a lot of good information. Also, if you use the search function,a lot of the time you'll find what you need. Some other forum's search functionsuck but this one is pretty good. Ifyou don't find what you need, post up and people will help you the best they can.
ORIGINAL: Adionik
The driver mod is getting better at driving in general. Neon3se is just a nut hugger on graphite, despite having a hot girlfriend.
#24
ORIGINAL: Freerider
good luck
#25
#26
ORIGINAL: Freerider
Yup, keeping it on the stock ECU for a while as well. I need to ask you some questions next time I catch on on instant messanger about what you did for timing...
Anywho, we will see once I start mocking up everything on the car how this will go.
#27
Thanks for the support you guys but this is becoming very hard to tune a neon I thing ill do what freerider toldme stay with the cold air intake and exhaust lol.
O and about the Integra it does have a Japanese engine it did came from japan but it's I guess that's hom much you guys know aboutJDM'S ACURA and Honda its the same **** they both have V-tech.
#29
ORIGINAL: rsalgado29
and by the way...
V-TECH:
VTEC:
if the mustang from tokio drift had an engine swap.
#30
