SRT-4 to Neon engine swap help
Hey guys,
I'm looking for some information on the SRT-4 to Neon engine swap. I have a 2002 Neon ES.
Questions:
-Can you give me an estimated price for total engine swap?
-What parts do you need to do so?
-Do you know of any websites, articles, or anything on the subject that can help me out.
thanks for all of your help. it is very appreciated.
Questions:
For the SRT-4 turbo engine, you will need the following parts:
Engine and Tranny
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Lower Motor Mounts (the hole in the lower mount is larger for larger bolts)
SRT PCM (wont' need the bracket if swapping into an 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line from tank to engine bay
Fuel Pump
Flex Fuel line from solid fuel line to fuel rail
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + o2 Housing
Lower Control Arms (they're stronger yet the same in shape)
Some options parts would include:
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
Rotors
The stimated cost will be anywhere from $3,000-$5,000 depending on many factors...if you install it or not, are you buying a donor car, or just the engine/tranny, and costs for misc. parts, etc...
Engine and Tranny
Intercooler Piping
Intercooler
Radiator Hoses
Coolant Bottle
Fuel Pump
o2 Sensors
Knuckles
Calipers
Rotors
there is guy that will do the motor installed for $5500
http://www.srt-4store.com/index.php?page=swaps
hey im ready to get the money and make the trip down there on your website site srt4store.com i cant find any info about where you are at i cant even find a phone number to call can you please at least give me number to get in contact with you srt4store im very interested in your srt 4swap package but dont know how to get in touch with you
ok now i know where its at Im in VA so i needa number or something
Trending Topics
What will this really help out with?? I have been thinking. I would want to replace all of the stuff with better parts anyways. I don't really want to do this myself...its too much. That place in PA is sounds great and i live in Ohio so it won't be that bad. Paying 5500 and then just replacing most of the stock parts doesn't make much sense. If I just put on a turbo, new exhaust, and some engine stuff on my ES wouldn't that be fine? I would only be missing out on that 0.4 liters right?
i have a 2000 sohc auto neon ive got a lot bolt ons but i wanted to do the 5 speed swap and build my motor but at the cost id rather just get the srt 4 motor and tranny so how can i get srt4store.com phone number i cant find it on the site
