strut bar
Old Feb 16, 2007 | 02:52 AM
Kalevra's Avatar
Kalevra
Default strut bar
Ok, I was thinking about buying a strut bar to better the handling and add some 'flare' under the hood. Now, my question is... will taking off the 3 bolts on the strut towers adjust anything or screw up the suspention? or are they safe to take off without screwing it all up?
Old Feb 16, 2007 | 03:25 AM
Kalevra's Avatar
Kalevra
Default RE: strut bar
anyone have an answer for me?
Old Feb 16, 2007 | 03:46 AM
Izero's Avatar
Izero
as long as you dont jack your car up at the same time, you will be fine..... im pretty sure you will not have any problems if you follow the directions that usually come with the bar.....im doing the same thing as soon asi get my car back from the trasmission guy.
Old Feb 16, 2007 | 03:48 AM
Kalevra's Avatar
Kalevra
ok, it's gonna be a cheapy off e-bay, i dont have the money for a name brand one. even if it doesnt do much it still will look cool
Old Feb 16, 2007 | 08:14 PM
03neonRT's Avatar
03neonRT
Nope you will be fine...the front strut bars dont do that much in the area of improving handling on our cars anyways, so you dont need to spend $120.00 on a DC sports one. The Vibrant or even Ebay kind will be fine for a little show, and little added performance.
Old Feb 16, 2007 | 09:46 PM
ewetho's Avatar
ewetho
Have fun. If on the ground first no problems at all. If you are airborne you may need to have someone hold the strut back up. But as far as alignment issues NONE. Just have fun. Just added a rear myself and it was a big improvement.
Old Feb 17, 2007 | 03:23 AM
Kalevra's Avatar
Kalevra
Thanks for the help. this site and you guys have been very helpful with everything. I dont know where I would be without this.
Oh, and I ordered the strut bar and I will tell you how it went.
Old Feb 17, 2007 | 06:42 AM
Freerider's Avatar
Freerider
haha, gratz on the strut bar. Hope everything goes well.
I have a DC (front and rear) on mine... i have pics in my gallery of it. Looks so nice. Make sure your garage is fairly level... doing the install on a slope is not recommended. (Oh... and you should feel a little less body roll when cornering really hard)
Old Feb 17, 2007 | 11:29 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
if your only removing 3 out of the 4 you shouldnt have any kind of problems with the strut 'falling down' hell, i didn mine with the car sitting in a level driveway. it took the better part of 5 minutes for the front. the rear was a bit more tricky as i had to cut out two small slits to lineup with where the bar would go through the trunk liner
i also had a problem with my bar being too 'high' and close to the hood. it cleard just fine except it caused my windshield washer nozzels to break off at the bottom tip. i simply replaced them with some aftermarket led ones which had shorter stems and ran my washer fluid lines through the hood support and the problem was solved.
ps. i have yet to hook up the led lights
