Vibrant Strut Bar Question...
Old Feb 22, 2007 | 07:25 PM
Izero's Avatar
Izero
Default Vibrant Strut Bar Question...
so i have a vibrant front strut bar, i am wondering about the bolts that connect the brackets to the bar, do i tighten those until i cant tighten them anymore, so that the bar cant pivot or is it meant to pivot? i'd like to install it today but im not sure what to do about those bolts...
Old Feb 22, 2007 | 07:36 PM
nicks2kes's Avatar
nicks2kes
Default RE: Vibrant Strut Bar Question...
just slap it on bolt it down and tighten, no more than 5 min
Old Feb 22, 2007 | 08:03 PM
Freerider's Avatar
Freerider
You know they are tight when you pull on the tower bar and nothing gives.
The car should move with the tower bars
Old Feb 22, 2007 | 09:27 PM
Izero's Avatar
Izero
gotcha, and do you guys know whay the torque specs are for the 3 nuts that you take off the top of the tower?
Old Feb 22, 2007 | 09:30 PM
Freerider's Avatar
Freerider
Technically I think they are 25 ft-lbs. They are tight enough if you just install them and tighten the bolts as best you can. If the strut bar doesnt move when you grab it and pull on it, your good.
Old Feb 23, 2007 | 12:22 AM
Izero's Avatar
Izero
[sm=thanx.gif]
Old Feb 23, 2007 | 01:43 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
i posted this in the other strut bar thread, but it might be useful to ya:
igot ebay ones, no isues except it snapped the bottom of both my washer fluid nozzels, as they stuck down just a bit too far and came into contact with the bar each time i shut the hood. this was a simple fix by getting some cheap LED nozzels at autozone. (which i have yet to hook up)
