Neon 02 vibrating
Old Feb 26, 2007 | 12:59 AM
buc_homi's Avatar
buc_homi
Default Neon 02 vibrating
hi everyone i'm new here and i'm having a problem with my 02 neon, when I stop the rpm go just above 500 and the car starts vibrating a lot, i put it Nuetral and the rpm go up a little and the vibration dissappears, this happens when the transsmision is on Drive only and the AC is off, when I turn it on theres no vibration. Someone having this problem?
thank you
Old Feb 26, 2007 | 01:06 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: Neon 02 vibrating
check your motor mounts. you most likely need some new ones
Old Feb 26, 2007 | 02:00 AM
qnr69's Avatar
qnr69
my car does the same goes down to just above 500 rpm is it supposed to?
Old Feb 26, 2007 | 02:14 AM
01neon01's Avatar
01neon01
welcome to the club. i mean the unexplainable vibration club. mine does that and has been for a while and i still cant figure out what the problem is.
ewetho's Avatar
ewetho
Should be a tad higher I would think.
Old Feb 26, 2007 | 02:56 AM
Andpto's Avatar
Andpto
same problem here i ve been reading around the forums, and most people say its motor mounts but im still unsure. It happens alot to me and twice i could hear the car bog down like it was going to die
Old Feb 26, 2007 | 03:00 AM
Adionik's Avatar
Adionik
My 02 vibrates like hell. I think I need a wheel alignment because my hand really shakes when i'm on the high way.
Old Feb 26, 2007 | 04:47 AM
kevo1123's Avatar
kevo1123
I had my motor mounts replaced and my engine still vibrates as well. Dont really know what the problem is, but alot of people have it.
Old Feb 26, 2007 | 08:29 PM
spikeymikey87
its normal. its just that when the rpms go down so low it shakes. its kinda like when a car stalls out it shakes like that before stalling. its normal
Old Feb 26, 2007 | 08:48 PM
darlin's Avatar
darlin
Hey yeh I have a 2001 and she doesn't shake so much.. but when I am excelerating sometimes I here this friggin rattle almost like there is a peice loose and is clanking around.. I am about annoyed anough with it to take it to visit my friend whos a mechanic.. any ideas.. I dont think it is motor mounts because my engin is shaking you know its just a vibration noise on the passangers side under the hood somewhere..
