Installing SRT-4 shocks and springs into a 03 neon LE
Old Mar 8, 2007 | 01:43 AM
R3S's Avatar
R3S
Default Installing SRT-4 shocks and springs into a 03 neon LE
Hi, this is my first posting. Have a 03 Neon LE ATX. I bought on Ebay a complete SRT - 4 wheels and tires package, but unfortunately I cannot install them as the tires hit with the OEM strut perches. I am thinking on bidding for a set of used srt-4 shocks and springs on ebay, but want to know first if these can be installed in my car, and if the stock shock upper plates can work for installing the shocks....
Thanks, Please let me know.
Old Mar 8, 2007 | 02:09 AM
das2123's Avatar
das2123
Default RE: Installing SRT-4 shocks and springs into a 03 neon LE
I know the tires won't fit on a first gen, so the same may go for the 2nd gen neons as well.
Old Mar 8, 2007 | 02:23 AM
djmagic's Avatar
djmagic
If anything you can get lower profile tires because I have no idea on the suspension.
Old Mar 8, 2007 | 02:31 AM
das2123's Avatar
das2123
IIRC, the stock SRT-4 tires are a 45 tire, so a 40 should work.
Old Mar 8, 2007 | 05:27 AM
03neonRT's Avatar
03neonRT
ORIGINAL: das2123
Stock SRT-4 tire size is 205-50-17...any 45 series tire (and lower) on a 17" rim will work on stock 2nd Gen suspension. As for the SRT-4 struts, they will bolt up 100% the same as your stock Neon struts. I wouldnt suggest buying used, but it really depends on the price. You can get brand new Tokico HP "Blues" struts for around $250...
Old Mar 8, 2007 | 11:21 AM
das2123's Avatar
das2123
ORIGINAL: 03neonRT
ORIGINAL: das2123
So if a 2nd gen owner wanted to run the stock SRT-4 tires and wheels, they would just need to buy the struts also?
Old Mar 8, 2007 | 01:54 PM
03neonRT's Avatar
03neonRT
ORIGINAL: das2123
ORIGINAL: 03neonRT
ORIGINAL: das2123
Correct, or go buy aftermarket struts like the Tokicos...
Old Mar 8, 2007 | 04:27 PM
tooslow's Avatar
tooslow
if you don't do srt springs it will raise your car since the perche sits higher
Old Mar 8, 2007 | 05:04 PM
djmagic's Avatar
djmagic
Yeah, I'm going to buy the 'blues" soon.
Old Mar 9, 2007 | 01:46 AM
R3S's Avatar
R3S
I purchased a complete set of wheels and tires from an SRT, the tires were runned only 12K miles, so they have a Very good tread life, and the Wheels are in IMMACULATE condition.. they came up toghether with the SRT spare wheel and tire (NEW never used) as well as with the original bag with Jack and bolt wrench.
I thought it was going to be a seamless fit, until I tried to install the wheels and found out.
RIght now I am checking on the shocks pricing, but I dont have money right now to purchase . I am considering serously aboutselling the wheels and tires... is anybody intrested?
