Check Engine light this morning- UPDATE
Old Mar 19, 2007 | 01:15 PM
chazlewood75's Avatar
chazlewood75
Default Check Engine light this morning- UPDATE
Here are the codes:
P0456 Evap Leak Monitor 0.020 Leak Detected A 0.020 leak has been detected in the evaporative sstem
P0517
Battery Temp Sensor Circ Hi
I read how to fix the first code (456): tighten the gas cap and remove negative battery cable/wait 10/replace negative battery cable.
But what about the 517 code??? I just installed a CAI. Is there anything else that I needed to do after installing the CAI? A buddy of mine who owns and tunes a 3000GT VR4 said I might need to reset the ECU, but that's what I thought having the negative battery cable removed during the install was for. Anyone in the know about this?
Old Mar 19, 2007 | 01:37 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: Check Engine light this morning
i will tell u this the small evap codfe will not be fixed by a gas cap they are med and large u have a split hose some where
Old Mar 19, 2007 | 02:10 PM
chazlewood75
SPLIT HOSE!??? What should I look for? could it be the hose that i added on between the crankcase vent line and the CAI?
What about the Battery Temp Hi code?
Old Mar 19, 2007 | 02:11 PM
mike9fore's Avatar
mike9fore
do you notice any dif. in the way the car acts??
Old Mar 19, 2007 | 02:25 PM
chazlewood75
Not yet. It doesn't sputter or surge. I will recheck the work I did when installing the CAI. I have ready that the evap code is common though.
Old Mar 19, 2007 | 02:32 PM
chazlewood75
Guess I'll be checking the vacuum lines and the lines in and out of the evap cannister on my lunch.
Old Mar 19, 2007 | 02:42 PM
mike9fore's Avatar
mike9fore
thats a good start...yet, I think you should check the CAI...that would be my guess.....
Old Mar 19, 2007 | 02:51 PM
chazlewood75
there's not much to the CAI. It connected to the TB, I plug in the air temp sensor and connect the crank case vent tube tothe CAI.
Old Mar 19, 2007 | 04:30 PM
chazlewood75
Lines looked okay from what I could see. They are plastic with rubber elbow connectors. I am going to clear the code and see if it comes back. If they do, I might just take her by the stealership and have them fix it. [sm=headbang.gif]
Old Mar 20, 2007 | 12:43 PM
chazlewood75
I checked all the lines that I could get to last night. I made sure that they were all pushed into the rubber elbows. Then I cleared the code this morning and droveto work. I will repost if the CEL comes back with the same code.
