bigger rims problem.
Old Mar 19, 2007 | 10:14 PM
blackflame's Avatar
blackflame
Default bigger rims problem.
Hey guys,
I know that when you put bigger rims on a car it messes with the speedometer. How would you fix this problem?? Or is there even a way to accurately tell how fast you are going?
Thanks
Old Mar 19, 2007 | 10:24 PM
AirWolf's Avatar
AirWolf
Default RE: bigger rims problem.
I think 18s wouldnt be a problem Iknow alot of 1st gen and 2nd gen neons that run with 18s and have no problems with anything . might need to get some spacers but thats it . Im going for 18s no matter what more a show size.
03neonRT's Avatar
03neonRT
The only way to account for bigger diameter rims is get tires with thinner sidewalls to try and get the "overall" diameter of the rim/tire closer to stock....
Old Mar 19, 2007 | 10:33 PM
LowSlowNeon's Avatar
LowSlowNeon
With 18s you'll have a pretty low sidwall. So you will most likely bend your rims pretty easy if you plan on driving it as a daily. It will also be a rough ride most likely. 17s would be the better choice.
Old Mar 19, 2007 | 10:39 PM
AirWolf's Avatar
AirWolf
I actually want to hear from someone that has 18s and drives everyday on them to really know what I want to get.
Old Mar 19, 2007 | 10:46 PM
ewetho's Avatar
ewetho
Calculate it and depending on rim size get appropriate sized tires for the speedo.
Old Mar 21, 2007 | 03:00 AM
djmagic's Avatar
djmagic
I have 18's and it threw of mine like one mph, dealership can fix it but for a big amount. I have 35 series on min I think maybe 45. I have a few dings in my rims by curb check once and rocks. Just make sure you avoid potholes and avoid dirt at all possibilities. Had a stupid show and had a dirt lot and got dinged up. Anymore questions?
