bolts on/cam
Old Mar 24, 2007 | 12:34 AM
2003SXTneon's Avatar
2003SXTneon
Default bolts on/cam
Iamthinking about getting the cranecam #12. i was looking into it and i noticed someone mentioned it works best if you have all bolt ons, my question is what exactly are all the bolt ons you can do? and should i go with a Throttle body before i do the cam? i have a cai,headers,and exhaust already.
Old Mar 24, 2007 | 02:43 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: bolts on/cam
ourcars only have one header, but i think you have them all. a throttle body would be good, 55 would be a good size, but i would get the crane 10 unless you plan on using it for track only also, you should get new springs and retainers
Old Mar 25, 2007 | 05:17 AM
2003SXTneon
ya i think i am going to get a TB before the cam.do you know where to get a 55. i can only find the 60. are you runnin the 10? it's a daily driven car so i would like to get whats best for it. do i have to get both springs and retainers or can i just get the springs. and is it true that if i upgrade my cam i will have to run (premium gas 91) ? i know are cars only have 1header. thanks for the info bro
Old Mar 25, 2007 | 05:25 AM
spikeymikey87
no im not runnin a cam yet, but i know that the 10 is less of a radical cam so it would be better for a daily driver. not sure about the gas, and i would upgrade both just to be safe. not sure if you NEED to or not
Old Mar 25, 2007 | 05:52 AM
2003SXTneon
i would probably go with both (springs & ret.) your right its better to be safe. i'm not trying to f**kup my motor over something like that.
Old Mar 25, 2007 | 04:54 PM
lblackneon's Avatar
lblackneon
Good bolt-ons that will change airflow would be a header, cat-back exhaust, intake, intake manifold, TB.
check this site out.
http://www.allpar.com/neon/performance.html
Old Mar 25, 2007 | 06:57 PM
Freerider's Avatar
Freerider
good bolt ons are:
Header
Exhaust (cat-back, muffler, new high-flow cats)
Intake (CAI)
Intake Manifold
Throttle Body (55 - 60mm)
and that is basic stuff. The intake manifold might be a bit tricky, the wiring harness has to be taken off before you can even take off the intake manifold.
All of that is still very easy to do though.
P.S. I have the crane cam #12
Old Mar 25, 2007 | 07:54 PM
lblackneon's Avatar
lblackneon
Are u done with your installation yet? My car takes a bit longer to start than normal.
Old Mar 25, 2007 | 08:07 PM
Kapitald's Avatar
Kapitald
A couple other good upgrades would be a underdrive pulley and maybe some cam gears....
Old Mar 26, 2007 | 06:40 AM
lblackneon's Avatar
lblackneon
ORIGINAL: Kapitald
U don't need a cam gear unless u plan on advancing or retarding the cam timing.
The udp is also a good upgrade. That was the first performance part to be installed on my car. U can really tell a difference in the power when the AC is on. When the ac was off I couldn't feel a difference in power.
