Old DIY links
Old Jul 27, 2007 | 12:00 PM
steve05ram360's Avatar
steve05ram360
Default Old DIY links
Moderator's Note: A lot of these DIY articles are no longer maintained or have disappeared, hence the "Old DIY links" title. If you think one of the good DIY articles here should be its own separate article in the DIY section, please PM me.
Disclamier that applies to all DIY articles.
https://dodgeforum.com/m_306208/tm.htm
Your skill level will determine whether or not you should attempt any of these DIY's... do them at your own risk.
Use common sense when working on your truck... wear safety goggles when needed and I recommend a good set of mechanics gloves... I have GoJo's which have a rubberized palm fingers to grip nuts bolts better. They are tight fitting and work great.
1. Steering box adjustment
https://dodgeforum.com/m_657750/tm.htm
https://dodgeforum.com/m_899062/tm.htm
2. Sport Headlight mod
https://dodgeforum.com/m_899052/tm.htm
3. Wheel bearing change
https://dodgeforum.com/m_899058/tm.htm
4. Tranny service
https://dodgeforum.com/m_901049/tm.htm
5. Diff servicing
https://dodgeforum.com/m_652194/tm.htm
6. front 2500/3500 wheel bearing repack thread
https://dodgeforum.com/m_640907/tm.htm
7. Oil bypass install thread
https://dodgeforum.com/m_653443/tm.htm
8. BHAF install thread
https://dodgeforum.com/m_372134/tm.htm
9. Rear mini leaf pack install
https://dodgeforum.com/m_842685/tm.htm
10. Power Steering service
https://dodgeforum.com/m_856966/tm.htm
11. NV5600 Teardown
https://dodgeforum.com/m_864365/tm.htm
12. DIY Fuel Filter
https://dodgeforum.com/m_485543/tm.htm
13. Autometer Pillar Gauge install
https://dodgeforum.com/m_875603/tm.htm
14. Towing Mirror install
https://dodgeforum.com/m_892300/tm.htm
15. front spring/spacer install
https://dodgeforum.com/m_901296/tm.htm
16. Plenum gasket replacement
https://dodgeforum.com/m_249261/tm.htm
17. Water pump replacement
https://dodgeforum.com/m_224411/tm.htm
18. Fuel pump replacement
https://dodgeforum.com/m_402587/tm.htm
19. Belt tensioner replacement
https://dodgeforum.com/m_507439/tm.htm
20. Underdrive pulley install
https://dodgeforum.com/m_511458/tm.htm
21. B&M Shifter install
https://dodgeforum.com/m_910684/tm.htm
22. Getting your Build Sheet DIY
https://dodgeforum.com/m_922730/tm.htm
https://dodgeforum.com/m_292535/tm.htm
23. DIY, Sagging door repair
https://dodgeforum.com/m_923950/tm.htm
https://dodgeforum.com/forum/2nd-gen...r-fix-diy.html
24. DIY Brake Controller & Trailer Wire Install
https://dodgeforum.com/m_949158/tm.htm
25. DIY Round Filter on TB (see also K&N FIPK No More thread)
https://dodgeforum.com/m_950007/tm.htm
26. DIY 12v t-stat install
https://dodgeforum.com/m_961443/tm.htm
27. Kegger Intake Mod thread
https://dodgeforum.com/m_1162946/tm.htm
28. Quick Drain Valve from Fumoto Engineering
http://www.fumotousa.com/
29. Rear Drum upgrade info& DIY writeup (burried down below)
https://dodgeforum.com/m_1025264/tm.htm
30. Heater core & EVAP swap.
https://dodgeforum.com/m_879602/mpage_1/key_/tm.htm
31. DIY Tracbar install (3rd gen install)
https://dodgeforum.com/m_1040856/tm.htm
32. DIY Toe alignment
https://dodgeforum.com/m_1040882/tm.htm
33. DIY MSD 6A install
https://dodgeforum.com/m_405881/tm.htm
34. DIY Throttle Position Sensor Cleaning
https://dodgeforum.com/m_1059605/mpage_1/key_/tm.htm#1059605
35. PDFs of multiple years/parts
http://www.jameskowalski.com/Dodge/Parts/index.html
36. DIY Front Brake Threading Issues. (from Durango forum)
https://dodgeforum.com/m_1230920/tm.htm
37. Throttlebody Cleaning
https://dodgeforum.com/m_1193850/tm.htm
38. DIY front grill inserts
https://dodgeforum.com/m_1274495/tm.htm
39. Fix for surging that is not the TPS
https://dodgeforum.com/forum/2nd-gen-ram-tech/70222-another-fix-for-transmission-surge-at-cruise-speed.html
40. DIY Cruise Control Switch R&R
https://dodgeforum.com/forum/showthread.php?t=171504
41. DIY Headlamp Relay
https://dodgeforum.com/forum/showthread.php?t=171606
42. DIY Tip Pitman Arm Removal
https://dodgeforum.com/forum/2nd-gen-ram/184544-diy-tip-pitman-arm-removal.html
43. Oil Filter Info
https://dodgeforum.com/forum/2nd-gen-ram/188492-bigger-oil-filter-for-the-360-318-cheap.html
44. LED Dash DIY
https://dodgeforum.com/forum/2nd-gen...tructions.html
45. DIY Harland Sharp Rocker install
https://dodgeforum.com/forum/2nd-gen...r-rockers.html
46. DIY power steering pump rebuild
https://dodgeforum.com/forum/2nd-gen...p-rebuild.html
47. Oil Filter comparison
http://minimopar.knizefamily.net/oil....html#champion
48. Transmission Check Valve Delete
https://dodgeforum.com/forum/2nd-gen...ve-delete.html
49. Transmission Sure-Cure kit install
https://dodgeforum.com/forum/2nd-gen...with-pics.html
50. 46RE Rebuild
https://dodgeforum.com/forum/2nd-gen...y-rebuild.html
51. $30 DIY Oil Change
https://dodgeforum.com/forum/2nd-gen...-flame-on.html
52. Color Matching Your Grill
https://dodgeforum.com/forum/2nd-gen...grill-diy.html
53. Rebuilding your Limited Slip Differential
https://dodgeforum.com/forum/1st-gen...ml#post1866063
54. Roll-on bedliner DIY
https://dodgeforum.com/forum/2nd-gen...liner-diy.html
55. Starter Replacement DIY
https://dodgeforum.com/forum/2nd-gen...arter-diy.html
56. Fog Light and Head Light Schematics.
https://dodgeforum.com/forum/2nd-gen...og-lights.html
Performance Reviews
1. Edelbrock IAS Performer shocks on 1500 Ram
https://dodgeforum.com/m_1278648/mpa...tm.htm#1278648
https://dodgeforum.com/forum/2nd-gen...l.html#1278648
Old Dec 24, 2009 | 09:22 PM
Laramie1997's Avatar
Laramie1997
Bumped and Stickied.
