View Poll Results: What's in your engine?
Mobil 1
28.65%
Royal Purple
6.18%
Amsoil
5.62%
Valvoline Full Synthetic
7.30%
Pennzoil Synthetic
5.62%
Castrol Synthetic
6.74%
Quaker State
6.18%
Havoline Synthetic
0.56%
Whatever the shop sticks in
0.56%
Synthetic Blend (specify in a post)
3.37%
Rotella
6.74%
Conventional (dino) oil (specify in a post)
22.47%
Voters: 178. You may not vote on this poll
Motor Oil
Old Dec 13, 2009 | 08:39 PM
  #41
cmckenna's Avatar
cmckenna
Originally Posted by J415
I'm just curious, but what makes Mobil 1 so great. I mean, I keep on hearing that "it works great" but what about it makes it great. exactly how do you know its working. what exactly is it suppose to do and how do you measure it's effectiveness?
According to this test, it's not that great:
[IMG][/IMG]
I run Amsoil 0W30. Have driven a lot on this motor oil and it still looks as good as the day it went in. Works fine in triple digit temps to 30 degree mornings here in So Cal. Never had an issue with it. I have used many brands of oil over the years and, Amsoil, works the best in my truck.
Old Dec 14, 2009 | 01:54 AM
  #42
2001Ram's Avatar
2001Ram
^^ Where did you get that graph from? Who made it? Ill bet it was amsoil. So of course it is going to say that.
Old Dec 14, 2009 | 11:21 AM
  #43
cmckenna's Avatar
cmckenna
That test was conducted by an outside lab- not Amsoil. The graph was found on the Amsoil site. If it was conducted by an outside lab, there may be a way of obtaining the actual report upon request. I will call them and see about obtaining the report today.
I just spoke to them about obtaining a test report. All test reports are confidential and are not for public dissemination. Sorry I could not provide more detail on this. The only thing that they told me was the M1 is aware and is not disputing the results as they also use the same labs to have this testing done on their motor oil.
Old Dec 14, 2009 | 12:25 PM
  #44
J415's Avatar
J415
Not to dig on 95ram360, but the same thing happened with him. He's talked about why mobil 1 is so great...of course that was according to a class he said he took about mobil1. I wouldn't doubt that it was sponsored by them.
Old Dec 14, 2009 | 08:57 PM
  #45
004x41500's Avatar
004x41500
[IMG][/IMG]
im not dissing you or anything, but my question would be, why are they testing 0w30 amsoil, and not 5w30 as they did all the others? something there looks fishy to me. and ive heard that castrol causes quite a bit of sludge. though i cant prove this, nor do i have any evidence to support this, but ill stick with a full syn oil, and change the oil every 3000 miles.
thanks for that good bit of info though.
Old Dec 15, 2009 | 02:24 AM
  #46
cmckenna's Avatar
cmckenna
The reason they tested this particular motor oil is because it's their flagship motor oil. So, they compared their best against other flagship oils made by other companies. If you note the temp of the test it's around 150º C.
Everyone assumes that it's a winter oil and, that at higher temps, it fails to protect the engine as well as a higher winter rating which, is why they intentionally chose this low rated oil as it shows that even at high temps of 150ºC (not F) this oil does not break down and provides much better protection than a higher rated winter oil.
So, if you look at the graph and all the parameters more closely, there's nothing fishy going on here. There's also another 0W rated oil in that test as well so, it's not all 5W across the board. This was intentionally done to prove a point of how their lowest winter grade motor oil shows the least amounts of wear in an industry standard test against higher winter rated, top brand motor oils as well as Castrol's top rated 0W oil.
Like I stated before, I have never seen motor oil look new after driving on it for a while. The only question I don't understand is why they don't make it more available in stores so everyone can buy it.
Old Dec 15, 2009 | 09:24 AM
  #47
halfamil's Avatar
halfamil
Wal-Mart Supertech 10W-30 full synthetic with a Motorcraft FL-1A filter.Change them every 4-5 K.
Old Dec 15, 2009 | 03:05 PM
  #48
PurplDodge's Avatar
PurplDodge
I like that Pennzoil Platinum came in second to the Amsoil. Good oil at a great price.
Old Dec 22, 2009 | 10:04 PM
  #49
004x41500's Avatar
004x41500
[IMG][/IMG]
i found a similar chart, but it puts mobil up higher on the chart.
what would be the best protection as far as weight goes for year round use in fl? 10w40? im thinking about ordering 5 quarts of amsoil soon.
Old Dec 22, 2009 | 10:12 PM
  #50
PurplDodge's Avatar
PurplDodge
Well, that test was done 2 years before the later. Oil formulations can change in that time.
