Every Replacement Bulb/Lamp for your RAM
Old Feb 10, 2012 | 12:00 PM
Johnny2Bad's Avatar
Johnny2Bad
Default Every Replacement Bulb/Lamp for your RAM
OSRAM/Sylvania has a very handy and comprehensive list of the standard type numbers for lights, bulbs, etc for vehicles.
You can lookup most cars + light trucks. I pulled the numbers for my 96 Gen II Ram, to serve as a reference for same/similar trucks and also to give you an idea of how comprehensive the list is.
Handy to print out and put in the glove box.
High & low beam 9004
Parking light 3157A
Front turn signal 3157A
Rear turn signal 3157
Rear turn signal 1157
Tail light 3157
Tail light 1157
Stop light 3157
Stop light 1157
High mount stop lt 921
Fog/Driving light 893
Fog/Driving light 880
License plate 168
License plate 1155
Back up light 1156
Cornering 3157
Front side marker 3157A
Rear side marker 194
Ash tray 161
Glove box 1891
Step/Courtesy light 211-2
Step/Courtesy light 1004
Step/Courtesy light 194
Trunk/Cargo area 921
Under hood light 105
Instrument-general PC74
Instrument-general 158
Instrument-general 161
Instrument-general PC194
Check engine indicator PC74
Hi-beam indicator PC194
Seat belt indicator PC74
Brake warning PC194
Automatic trans ind PC74
Automatic trans ind PC194
Directional signal ind PC194
Ignition switch 1445
Radio dial 74
Website is at:
http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
Old Feb 10, 2012 | 12:02 PM
Augiedoggy's Avatar
Augiedoggy
good find thanks!
Old Feb 10, 2012 | 12:40 PM
Big time. Moving to FAQ section. This ones a keeper.
Old Feb 14, 2012 | 11:43 PM
gdstock's Avatar
gdstock
Thanks for doing the research and posting this Johnny2Bad.
This is good info.
Can't count the number of times I tried to read those itty bitty faded numbers on a bulb...only to get the wrong one!
Old Feb 17, 2012 | 01:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Nice addition to the section. However, I suggest removal of the old bulb in addition to looking it up on the website(so you have it for comparison). It leaves a little to be desired. I looked up the list for my 2000 and the reverse bulb is the wrong number(totally different bulb), and it also lists that Cornering bulb, that I'm pretty sure no Ram has. Just a heads up, that's all.
Old Feb 18, 2012 | 11:12 AM
Johnny2Bad's Avatar
Johnny2Bad
Yeah I can't argue against having a pulled sample in your hand. If there's an error we should try to correct it here in the Forum with the right bulb type #. Might not hurt to eMail Sylvania/Osram if only to see if they resond to corrections.
Do you think there could be a mid-year change issue here? Just asking because 2000 was one of those years when running changes were implemented. Is yours an early or late '00?
If we ever get to the point where we have known good info we could do a list just for 2nd Gens since it won't be that big a chart. If nothing else that link does some of the legwork for us; it's a nice start, but the usual cautions about 'net info always apply.
Old Feb 19, 2012 | 02:41 PM
zman17's Avatar
zman17
I hear ya, Your chart is for a 96 so there is bound to be differences. I'll pull that bulb tomorrow and post the number. As far as the cornering lamps go, none of us can help with that.
On a side note, date of MFR on my truck is 9-99.
Old Feb 19, 2012 | 03:31 PM
stewie01's Avatar
stewie01
Date of MFR on my '01 is 02-00
Old Apr 6, 2012 | 01:35 AM
Johnny2Bad's Avatar
Johnny2Bad
If any of you guys do a lookup at the weblink at the bottom of my Original Post, feel free to take a few moments and make a post for your year + model Ram. You'll probably have to enter it manually in a post. My OP is really only truly valid for a 96.
Eventually maybe we can get a nice comprehensive list for all the 2gen Rams. You can never just assume that anyone like Osram/Sylvania will always have the lookup available; it would be better if we didn't have to rely on them and could get it perma here.
