Old Feb 5, 2013 | 06:25 PM
  #10041
Jigabop's Avatar
Jigabop
if gasoline I call bs...if diesel I call bs on the "lean spot"
no such thing on a diesel...
they shouldn't be dumping smoke the entire time. if they are you don't have enough air.
if ya watch my youtube video of mine, you can see it dumps smoke till the turbos spool, but as soon as they spool the smoke is gone until I shift...then its the process repeated but smoke cleans up faster yet..
  #10042
dlyter09's Avatar
dlyter09
Quad turbo should be puttin down more HP than that.. Unless its tuned weak and that honestly would be a huge waste..
Old Feb 5, 2013 | 06:37 PM
  #10043
Wombat Ranger's Avatar
Wombat Ranger
That's why I call BS. Quad turbos would be so useless, not to mention expensive, and ridiculous to tune, I think he's just flapping his lip.
Old Feb 5, 2013 | 06:52 PM
  #10044
crazzywolfie's Avatar
crazzywolfie
without liars this place would be boring anyway so BS away.
Old Feb 5, 2013 | 06:57 PM
  #10045
Jigabop's Avatar
Jigabop
quad turbos would be one of those things where you do it just to do it...
seen it done before...
and hp was low...
basically a 3 > 1 compound setup. its taking triples 1 step further to try and decrease lag...but for the cost of doing that, I would rather just run carl's setup of compounds with a supercharger...you can't get faster boost than that...he had 5psi at idle, and still had the top end power from compound twins with no lag.
expensive setup, but worth it if you can afford it.
Old Feb 5, 2013 | 07:06 PM
  #10046
stewie01's Avatar
stewie01
Truck in last video sounds like ****.
Old Feb 5, 2013 | 07:16 PM
  #10047
Jigabop's Avatar
Jigabop
haha you wouldn't think so if you rode in it...superchargers arent quiet. you probably just aren't used to hearing one turning higher rpms at idle than it normally would on a gasser...diesel doesn't have the same RPM range as a gasser, so we run the blowers faster at idle than a gasser would to get the most out of the blower in our limited RPM range. which translates to boost at idle which unlike a gas engine, a diesel engine can take without breaking a sweat. (cleans up injector haze)
carl has enough fuel and air for 800+hp and hes got a built auto so you know it ***** and gets!
he has the only truck I know of with compound twins and a supercharger on a p-pumped 24v.
probably the only 2nd gen 24v with that kind of power and street manners as well..
  #10048
Yinzer's Avatar
Yinzer
It reminded me of when I was little. I'd shove an empty coke can in between the frame and back tire on my bike and pretend it was supercharged. Vrrrrrrrrrrllll Haha
Old Feb 5, 2013 | 07:21 PM
  #10049
Derick C.'s Avatar
Derick C.
I think it sounds awesome.
Old Feb 5, 2013 | 07:22 PM
  #10050
stewie01's Avatar
stewie01
He could have at least taken it for a ride instead of tapping on the gas pedal....
