Old Aug 21, 2013 | 04:55 PM
  #12331
aofarrell2's Avatar
aofarrell2
Exhaust leaks can be a major source of power drops. I've got a slight leak on the Dodge, need to tighten it a little more, but mine isn't big enough to cause any trouble.
If you were in the Ford world you would have hit the holy grail, due to their valve timing, but Dodge's don't seem to be effected as much IMO.
Old Aug 21, 2013 | 07:19 PM
  #12332
Jigabop's Avatar
Jigabop
I ain't got one of them fancy pants vdub tools there, but even if I did...doesn't change the fact that it was still the POS clamp that caused the leak
it was not the hose, hose is only 2 months or so old...I just just replaced the bastard earlier this spring/summer...
my screw type hose clamp fixed her right up and put a stop to the leak.
nothin little old 'murika couldn't handle
and it wasn't even a new clamp I used found it in the junk drawer of my toolbox
I toss old parts/bolts/springs/gaskets/etc (that are still good) in there for when I might need them again some day...that junk drawer has bailed me out several times.
Old Aug 21, 2013 | 08:36 PM
  #12333
redneck_ram's Avatar
redneck_ram
cleared the check engine tonight... got codes for no signal at cam, and crank sensor. also misfire codes. thinking its because of broken injector plugs. they dont clip onto the injector securely.
Old Aug 21, 2013 | 08:58 PM
  #12334
aofarrell2's Avatar
aofarrell2
Replaced battery cable, tightened starter motor mount bolts (lower one comes loose all the time, warped starter motor AFAIK), checked all fluids, checked lights again, tightened fuel regulator bolt, tightened exhaust manifold bolt, and filled the cab
Towing beefer to the locker in the stock trailer tomorrow, lets hope no breakdowns.
Looking at the front axle and tires, left tire seemed entirely out of whack as far as camber goes, I will double check when on some flat pavement tomorrow, but it looks like something up front is bent, might explain the terrible clanking noise heard when turning sharp left with the force on the left side, i.e. uphill turning left &c. Hate to say it but it looks like the axle might be slightly bent, or could be I am losing a tierod, or maybe both, this truck DID entirely break a tierod when we first got it, before we towed with it.
Old Aug 21, 2013 | 09:00 PM
  #12335
DeeJayh's Avatar
DeeJayh
Meh, oh well.
You do your thing, we'll do ours.
Don't like America, move the hell out.
EFFIN RIGHT!
Old Aug 21, 2013 | 09:06 PM
  #12336
DeeJayh's Avatar
DeeJayh
Muddin', 'nuff said
Old Aug 21, 2013 | 09:17 PM
  #12337
QuadCabLuv's Avatar
QuadCabLuv
Originally Posted by VWandDodge
*sigh*
Use the correct tool for the job.
Dumbass 'Murricans.
I have 3 different styles of those and 50% of the time there is not room to get those pliers in there. but most of the time I'm working on newer compact engine bays.
Old Aug 21, 2013 | 10:06 PM
  #12338
It is a known fact that the engineers that design these things NEVER have to actually work on them.
Old Aug 22, 2013 | 08:41 AM
  #12339
DeeJayh's Avatar
DeeJayh
Amen, same goes for everything. I do HVAC, plumbing, electrical, and remodeling... ever seen an architect's blueprint? Omg I wish I could meet half of them... so I could givem the ol' rudy tudy
Old Aug 22, 2013 | 11:13 AM
  #12340
merc225hp's Avatar
merc225hp
Try Zipties to hold them on or buy the little clips for them.
Filled it with gas, going to get the rear blocks and go get the winter beater on the trailer to bring it home on the weekend.
