Old Aug 13, 2013 | 10:14 PM
  #12231
stewie01's Avatar
stewie01
Goddonkey.
A couple of you guys
*I'm looking mostly at you techjockey*
told me about 5.5-6.5 qt......Like I said, Imma check it tomorrow and then hop in old Lemon Drop and cruise over to wally world and get another two quarts.
*edit*
7500th post. insignificant w00t!
Usually takes more with a filter drop versus just a pan drop, also depends on how much fluid actually drains.....
Old Aug 13, 2013 | 10:15 PM
  #12232
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Fluid was dripping out of the filter for quite a while until I dropped it.
Then another like half quart came falling out. lol
Old Aug 13, 2013 | 10:38 PM
  #12233
crazzywolfie's Avatar
crazzywolfie
you know you are suppose to check the fluid level with the truck in neutral before you drive it right?
Old Aug 13, 2013 | 10:41 PM
  #12234
dodge dude94
I did that.....I'm wondering if I had done it before the t-stat in the cooler had opened.
  #12235
stewie01's Avatar
stewie01
And go through all the gears before checking, P,R,N,D,2,1 than back up....
Old Aug 13, 2013 | 10:43 PM
  #12236
dodge dude94
Yep, did that too.
Even when it was going to slip and I didn't know it, everything seemed smoother. lol
I'm going to hopefully drive it tomorrow, but I'm not going to go back to driving it until I can get that checkvalve deleted.
Old Aug 13, 2013 | 11:12 PM
  #12237
aofarrell2's Avatar
aofarrell2
DD, the amount of fluid DOES vary, and if you recall correctly, I stated "IIRC' in my email lol... so anotherwards dont take it for fact.
Old Aug 13, 2013 | 11:13 PM
  #12238
aofarrell2's Avatar
aofarrell2
^So, since you'll be in England, you won't be here on DF?
BTW.
this is jibber jabber.
This isn't:
So I've put a total of 6.5 qts in it, had to put it up for the night. I'd had about 5.5 in it to begin with. Everything seemed fine, drove it down the road, seemed to be working. Go to pull away from the stop sign, SLIP THUNK.
Turn into a ladies driveway, reverse works fine..hmmm...*drive* SLIP THUNK.
SH!TTT!!! Nurse it back down to my house, check the dipstick. NOTHING. So I put a full qt in it, at least, I forget. Either way, Imma check it again tomorrow morning sometime to see what it's doing.
I should be able to be here still on DF, albeit 6hrs earlier (I think) than normally I would be now.
Old Aug 13, 2013 | 11:15 PM
  #12239
dodge dude94
Not sure if I recall correctly. The brake cleaner did some weird **** to me.
Nice.
Old Aug 14, 2013 | 01:50 PM
  #12240
dodge dude94
After 7.5 qts of fluid it's finally full.
Damn.
Seems to be smoother, holds the shift into OD a tad longer and the clunk that's plagued it for the past 4 months is not quite as bad. Hmmmm....
Also, how hot should the trans. cooler return hose be? Mine is hot but not so hot I can't touch it, just can't hold my hand there for any real length of time.
