Old Jan 12, 2014 | 08:01 PM
  #13271
BBartow's Avatar
BBartow
Jack-hammered out the old sidewalk at sister's house and hauled the concrete to the local concrete plant. Had to be a little over a ton, the truck handled it just fine. No pics since I didn't have a camera with me.
Also put 21 gallons in her.
Old Jan 12, 2014 | 08:07 PM
  #13272
Spillage's Avatar
Spillage
Today I prep'd for an A-Pillar gauge pod install.
The pod is supposed to screw over the top of the factory trim, but being that it fits into the opening in the end of the dash, and tucks behind the door seal all the way up the side, it cant go anywhere, so it's going in by itself.
I installed the gauges (Wideband O2, Vacuum, Engine Oil Temp) and speaker into the pod, then ran the common wires to a connector at the bottom of the pod (Wideband has its own cable to its controller).
The Wideband controller I put on a bracket that I tucked under the bottom edge of the steering column valance, picking up one of the existing screws.
From the new connector I ran wires and the vacuum line down the pillar following the speaker wire, behind the fuse panel, and under the dash.
I punched through the top of the large loom grommet in the firewall, and routed the sensor wires and vacuum line to follow other legs of the factory loom to the desired destinations.
The remaining tasks for next weekend are; install the sensors, and tap into the factory loom for power supplies (ground, uninterrupted, switched, and lights).
I'll take some pics before and after final install.
Old Jan 13, 2014 | 11:56 AM
  #13273
JRedRam's Avatar
JRedRam
Originally Posted by Spillage
Today I prep'd for an A-Pillar gauge pod install. The pod is supposed to screw over the top of the factory trim, but being that it fits into the opening in the end of the dash, and tucks behind the door seal all the way up the side, it cant go anywhere, so it's going in by itself. I installed the gauges (Wideband O2, Vacuum, Engine Oil Temp) and speaker into the pod, then ran the common wires to a connector at the bottom of the pod (Wideband has its own cable to its controller). The Wideband controller I put on a bracket that I tucked under the bottom edge of the steering column valance, picking up one of the existing screws. From the new connector I ran wires and the vacuum line down the pillar following the speaker wire, behind the fuse panel, and under the dash. I punched through the top of the large loom grommet in the firewall, and routed the sensor wires and vacuum line to follow other legs of the factory loom to the desired destinations. The remaining tasks for next weekend are; install the sensors, and tap into the factory loom for power supplies (ground, uninterrupted, switched, and lights). I'll take some pics before and after final install.
Where did you get that pod?
Old Jan 13, 2014 | 12:22 PM
  #13274
Jigabop's Avatar
Jigabop
you want it to go over the top of the factory trim or it will not stay still.
use double sided tape to attach it to the factory trim.
Old Jan 13, 2014 | 02:20 PM
  #13275
AppelH's Avatar
AppelH
Originally Posted by Gary-L
I threw the center caps from my 2nd Gen on e-Bay last week with an opening price of $10. On Friday, I received this ridiculous e-mail from another e-Bay member (note my response):
The caps are up to $23.50 with a little over an hour remaining for the auction. I had no idea the center caps were in such demand. Oh well, just more money for me.
[/SIZE][/FONT][/COLOR]
I think I was following this auction, I have been looking for some for my Rango, as all four are missing. I think the auction ended at like $26 or something like that right?
Old Jan 13, 2014 | 03:00 PM
  #13276
Gary-L's Avatar
Gary-L
Veteran: Navy
Nope. http://www.ebay.com/itm/Dodge-Ram-Durango-Wheel-Rim-Center-Caps-/331100743955?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d17246913. I wonder what happened to the chump who offered me $10?
Old Jan 13, 2014 | 09:12 PM
  #13277
Spillage's Avatar
Spillage
It's a Glow-Shift pod.
And I got it via Glow-Shift on Amazon.
Old Jan 13, 2014 | 09:24 PM
  #13278
Spillage's Avatar
Spillage
I'm not confident that double-sided tape would hold up to cab heat in summer.
From trial fitment, it seems pretty sturdy by itself... if it proves not to be, it will be easy enough to put the stock one underneath.
Old Jan 13, 2014 | 09:54 PM
  #13279
Use the two-sided tape they use to stick the emblems on the side of the truck. It will never come off, regardless of interior temp. (well, ok, if the truck burns to the ground, it more than likely won't survive that.....)
Old Jan 13, 2014 | 11:12 PM
  #13280
redneck_ram's Avatar
redneck_ram
I have the same pod... either do what jigabop suggested, or get some sort of way to attach that pod to the naked pillar. Mines mad loose at the top without the dactory trim piece in place. Doesnt move around too much nut still hangs down.
