Old May 14, 2014 | 01:32 PM
  #13941
Ham Bone's Avatar
Ham Bone
There are nv4500 rolling a round behind Cummins pumping out twice the torque you have.
All the diesles have is a bigger mainshaft and a couple more splines on the input shaft
Old May 14, 2014 | 09:43 PM
  #13942
tincan57's Avatar
tincan57
I got the 98 back today with a new idle control valve, the speedo/tach is back up to par, and a turbo thrush muffler is installed and running with a reserved rumble, (for old guys). ^ add new sensor K.
Old May 15, 2014 | 12:13 PM
  #13943
Jigabop's Avatar
Jigabop
drove it...it has A/C. The S10 does not.
Old May 15, 2014 | 01:37 PM
  #13944
Wombat Ranger's Avatar
Wombat Ranger
Not trying to be a dousche here, but...
try 4 times as much torque
Swap that the input is bigger in diameter, mainshaft is 29 spline instead of 23.
Keegan your problem is most likely in the shift fork linkage. If you are under a year and 12000 miles that thing is still warranted. otherwise pull the top plate and check it out.
Edited spline count, fat finger.
Old May 15, 2014 | 01:40 PM
  #13945
aofarrell2's Avatar
aofarrell2
Swap that the input is bigger in diameter, mainshaft is 29 spline instead of 22.
Thanks Wombat. It should still be under warranty, at least I hope...
Old May 15, 2014 | 01:48 PM
  #13946
Ham Bone's Avatar
Ham Bone
Oops I got them backwards.
Oh well, you guys get the point
Old May 15, 2014 | 04:51 PM
  #13947
redneck_ram's Avatar
redneck_ram
finally fixed those ruts i made back in march... how did i do it, you ask?
i plowed the crap out of my lawn using my truck, and plow. then i back dragged all the dirt to semi smooth it out. then used a lawn rake, and got it almost perfect!
grass seed, and fertilizer is next...
Old May 16, 2014 | 09:22 AM
  #13948
Grass seed might just as well be gold dust for the price they want for it around here......
Old May 16, 2014 | 11:36 AM
  #13949
aofarrell2's Avatar
aofarrell2
Got the dodge working again...
Got my shifter stub out so I could see the rails - and just as I figured the reverse/fifth rail was out of alignment. How the hell my stub managed to slip out of that I have no clue. Nothing was worn out or otherwise damaged. It was easy enough to fix - two big flatheads, push down the cover and twist it counter clockwise, it pops up, pull the stub out, and there are the rails. Rail to the left is the one I wanted. Put the transfercase in neutral, set park brake, start the engine, use the screwdriver to pop the rail back into alignment (in this case, out of reverse), put everything back together, and voila it works...
Old May 16, 2014 | 04:58 PM
  #13950
tincan57's Avatar
tincan57
I put the 98 farm truck back to work at the barn, (the one with puny axles), ran trips for the garden stuff (grow & eat variety), picked up a tri-pod for the camera (thanks to Wombat Ranger and his cell phone photo of Blue 231). K.
