Old Aug 20, 2007 | 10:56 PM
  #131
cdusthockey's Avatar
cdusthockey
Default RE: What Did You Do To Your RAM Today?
changed my rear brakes because the pad seperated from the shoe assembly. every time i touched the brakes the left rear would totally lock up and not free. had to put it in reverse to break it loose, then drive forward. that was an interesting 2 mile drive back home, with the addition of a bunch of flat spots on my left rear.
Old Aug 21, 2007 | 09:53 PM
  #132
padodgeram's Avatar
padodgeram
put on my bushwackers extend a flar , next week my 3" body lift will go on , this spring ill be putting a 5 " susp lift on and 34 x16 tires and rims..
[IMG]local://upfiles/40785/47AF1A856A4741988E38AC987C2AFBF4.jpg[/IMG]
[IMG]local://upfiles/40785/E8640A2883D1481A950E2F18099ADD08.jpg[/IMG]
Old Aug 21, 2007 | 09:58 PM
  #133
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: ryans590
well i bought/ordered some new parts today...180 deg t-stat, new sirpintine belt (damn they are more expencive than i rember or i got hosed gonna check another place tomorow), new autolite plugs, msd wires napa brass cap and roter. now i just need time to put it all in, hopfully this week and then next week itll be 4.10 gears
hey what do you guys think, should i do the coil while im at it? if so whats a good brand?
MSD blaster 3 coil is pretty popular.
Summit has a gator grip serpentine belt for 34.99. Is that better than what you got?
Old Aug 21, 2007 | 10:38 PM
  #134
Fox Fader's Avatar
Fox Fader
ORIGINAL: padodgeram
Big tires will really set thet beauty off, keep it up.
Old Aug 22, 2007 | 12:38 AM
  #135
ryans590's Avatar
ryans590
ORIGINAL: aim4squirrels
ORIGINAL: ryans590
i dont think i wanna go with the blaster 3 i think im gonna stick with a single, i asked standerd MSD coil and aparentley they only make it untill '96 then dodge changed the plug from a pin style to a blade style anyone else ran into this? what coils are you all running?
i think im gonna start a thread about coils
my serpentine belt was $41 (CDN) so about the same as the summit one
Old Aug 22, 2007 | 04:22 AM
  #136
padodgeram's Avatar
padodgeram
thanks fox.....ryans590 you will need this to work with the msd coil Adapter Harness, Adapts ACC-140021 to Dodge Truck/Jeep, Each ....These ACCEL ignition coil adapter harnesses will allow you to connect the coil to the factory wiring harness. The ACCEL ignition coil adapter harnesses include the necessary connectors for a quick and easy installation...... i use the msd coil # 8228...
Old Aug 24, 2007 | 12:33 PM
  #137
Fox Fader's Avatar
Fox Fader
I went to the land fill today,
got home and I had to pull two screws out of my tires and plug one of 'em.
too hot for this stuff, haha
Old Aug 24, 2007 | 12:52 PM
  #138
Silver_Dodge's Avatar
Silver_Dodge
I have several things in the works, but waiting on either parts or time. I'm itchin' to do some mods though, but what can I do?[sm=confused06.gif]
Old Aug 24, 2007 | 03:45 PM
  #139
ramit2001's Avatar
ramit2001
I seen my transmission in a pile of parts ona bench. It should be all back together tomorrow and in the truck.
Old Aug 24, 2007 | 11:08 PM
  #140
IndyRamMan's Avatar
IndyRamMan
4 new ball joints, new brakes, new pitman arm, alignment.
