Won't really hurt anything but I don't recommend it, because those different viscositys won't mix well.
Are you planning on keep the axle full width or cut it down to be close to stock width? I have all the measurements of how much you need to cut off each side to make a D44 Waggy width so you can use off the shelf axles instead of having to get custom axles made. Let me know as it is what I did with the front axle in my Jeep. And just in case you didn't know Waggy width is 61" and a TJ/XJ is 60".
I am building a 35 spline spidertrax 9" for the rear, it will be 65" wide as well. Front will get a regear to match the rear and not much else initially, then a real build later on when I get tired of breaking it.
@Tincan I will put up pics of the '69 when I pick it up.
They will mix together no problem and the engine won't care one bit.
From www.chevron.com:
Can I mix different viscosity grades of motor oils?
Yes. It is always advisable to not mix motor oils, however, different viscosity grades of the same motor oil are compatible. Be aware that mixing viscosity grades will turn out a product that is different in viscosity than either what was originally in the engine or what was added.
And this from a Cadillac technician:
It's not so much "what could happen" as it is you just don't know what you end up with.
Like I said you just end up with something that has unpredicable properties.
As well, if they aren't the same API grade that could have reprecussions because of different additives.
I have not gone synthetic on anything..............call it a trust issue. However, the diesel's fixing to roll 250k. So Jig's, your thoughts would be appreciated (diesel or gas for the gas guys). K.
Edit: I'm doing the home work......detergents, leaks, consumption associated with full synthetic. I just don't see much feed back for long time users (pros & cons).
The diesel since the last oil change (Pennzoil 5w-30) has not been hauling (except for the 01), but as quick as the wife wraps up in NC, hope to go back to hauling/flippin vehicles. I'm looking at Pennzoil Platnum or pure plus. My diesel guy mentioned Schaeffers 5w-40 or 7000 (we have seen -6 degrees this winter). Loads around 8k. Using Fleet guard filter. Currently change every 5k.
Gassers, looking at Platnum plus or Ultra 5w-30. General transportation since December (bed loads only). Currently change every 3k.
So if anyone can give some history on Pennzoil Platnum plus or Ultra when posting in this thread for oil change I'd appreciate it. K.
Edit: Currently my Ram 2500 CTD is on 15w-40 Pennzoil Long life diesel oil (stated above in error).
Edit: Will run 10w-30 in 97
Sorry man but I'm gonna have to argue that one.
All that study says is that if you take 4 quarts of 10w30 and add one quart of 5w30, you will end up with - drumroll......
9w30.
Just a hunch, the engine will never notice. These were not a close tolerance or high performance engine from the factory. In a new Hemi with 470hp, 8 coil packs, multiple computers and a gazillion engine management systems working together, different story.
