Old Sep 22, 2009 | 10:21 PM
  #1421
Augiedoggy's Avatar
Augiedoggy
Installed diamond plate mudflaps to stop the tires from throwing stones and replaced the outer lower windowsill weatherstripping (no more bubbled rubber coated rust look)
Old Sep 23, 2009 | 09:50 AM
  #1422
Sheriff420's Avatar
Sheriff420
Originally Posted by EndIsNear
Got it muddy Yea, shes two wheel drive...
gotta keep that tach pegged in 2wd just to keep her moving.
Old Sep 23, 2009 | 12:35 PM
  #1423
TimSully88's Avatar
TimSully88
Hey, where did you get the bottom weather stripping for the window???
Old Sep 23, 2009 | 10:13 PM
  #1424
dodgeram07's Avatar
dodgeram07
removed the under drive pullys and put stock back on
Old Sep 23, 2009 | 10:16 PM
  #1425
Twisted Metal's Avatar
Twisted Metal
Did the 7k oil/service which includes:
5 Qts. Royal Purple 15w50 oil
Mopar M090 filter
Wash and clean AEM Dry flow(put in the paper on that came with my Edelbrock till tomarrow so the AEM can dry fully)
Retorque Valve covers(yeah the bottom 3 on both sides where loose)
Can of Seafoam in tank and oil (every 5th service)
Grease Pitman and Drag Link( only 2 grease fittings on truck)
Top off all other fuilds(time to switch to winter wiper fluid, we've had frost here already)
Normally this takes me about 1.5- 2 hours start to finish, add clean, check,adjust brakes to above. But just had the wheels off to rotate tires so did it then
Also dropped the pan on the transmission, changed filter with a Wix one. New pan gasket and filled with Valvoline Syn ATF+4.
Finally got around to installing my check valve delete(thanks aim4squirrels)
Lastly found out my new(used) spare was flat. This is tha last time I trust a man selling 10 dollar tires!
Old Sep 23, 2009 | 10:32 PM
  #1426
Oren09's Avatar
Oren09
Busy day Twisted.
I'll be winterizing soon. Need to flush coolant and will be going to lighter oil next change.
$10 tire..? I wouldn't trust that for my lawn tractor :P
Certainly not a spare.
Old Sep 23, 2009 | 11:21 PM
  #1427
99_ramsport's Avatar
99_ramsport
Put a new grill insert on my Sport. Looks great
Next week my SS brake lines should be in so the truck will be going in to get a complete overhaul. Alot of new parts! about $500 total in parts.
Old Sep 23, 2009 | 11:27 PM
  #1428
PurplDodge's Avatar
PurplDodge
Love the SS grille inserts!! I have always wanted some!!!
Old Sep 23, 2009 | 11:39 PM
  #1429
BlueBeast2's Avatar
BlueBeast2
Dropped off a crap load of parts to my engine guy. Might see my engine back this week
Old Sep 24, 2009 | 05:43 AM
  #1430
Sheriff420's Avatar
Sheriff420
you've been saying that for how long? i swear i would have taken my engine back by now if i was you.
look at what i got a day early.
