Old Jan 18, 2020 | 01:21 PM
  #16361
Spillage's Avatar
Spillage
Stripped and pulled the dash... dropped the heater-a/c box... and temporarily put the dash frame back... 3hrs total.
It’s drivable until I get the heater box overhauled.
The plastic in behind the dash cap isn’t looking too pretty... I’ll post on this later.
Old Jan 25, 2020 | 05:07 PM
  #16362
Spillage's Avatar
Spillage
Started on the jigsaw puzzle today...
The right side I found enough pieces to bridge the gap.
The left side is a different story... I’ve got a few decent sized pieces to put together, but as I glue them up, they’re breaking in other places... it’s like a block of crumbly cheese... look at it sideways and it falls apart... in just one section, what started as 3pcs soon became 7... and I’m not seeing enough pieces of any consequence to finish it off... there may be pieces trapped in behind that I haven’t found yet... fingers crossed.
Once I get enough to bridge all the gaps and get the dash pad mounting points, I’ll take it out and reinforce the back... lots of reinforcing.
Old Jan 26, 2020 | 05:49 PM
  #16363
Spillage's Avatar
Spillage
Got most of the drivers side back together (I think).
Next week I take it out and start the reinforcement process.
Old Jan 26, 2020 | 05:56 PM
  #16364
Spillage's Avatar
Spillage
Also pulled the cowl, cleaned it up, and painted it.
Then scuffed the shiny plastic of the cabin air filters, and painted them.
And at the end of the day, installed them.
They’re a snug fit to the underside of the hood, so I think I’m going to put some teflon tape on the underside of the hood so it doesn’t chafe.
Old Jan 26, 2020 | 11:13 PM
  #16365
Ramman18's Avatar
Ramman18
Looks good, spillage. I wonder if getting a whole dash from the junkyard would be warranted? I mean if you have to mend so many pieces than maybe it's an option?
Old Jan 27, 2020 | 07:16 AM
  #16366
Spillage's Avatar
Spillage
I tried to find a heater box locally so I could rebuild it ahead of time, but nobody has 2nd Gen’s around here... “they’re too old”.
Also, I could be no better off with what I find.
Right now I think I have enough to make it work... between the reinforcement I plan putting in the back and the new pad in front, it should be ok... the pad will support the frame;-)
  #16367
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
are those from Geno's? How do you like them? I thought they would lol ugly but they look good! Hey snow where you are at?
Old Jan 27, 2020 | 07:15 PM
  #16368
Spillage's Avatar
Spillage
Yes, from Geno’s.
I don’t mind the look... and if it’ll keep leaves out of my fan, I’ll take it.
Can’t comment on the effectiveness of the carbon filter (smell reduction) until I get the heater box back in.
I had to trim the bottom edge a bit to get back to the mold line, so the edge looked finished... other than that, the fit is ok.
As I said earlier, it is right up against the underside of the hood, so I suspect it will chafe the paint... hence my plan to put some Kapton tape on the back edge of the hood.
Old Jan 27, 2020 | 09:44 PM
  #16369
MoparFanatic21
Yes, from Geno’s.
I thought about getting them but I was worried about water soaking the filters
Old Jan 27, 2020 | 10:07 PM
  #16370
Spillage's Avatar
Spillage
It’s a nylon, kind of like a scotch-brite consistency.
Whilst it will get wet, the water will drain to the bottom and drip into the trough under the cowl (where rain presently goes).
Not being porous, I don’t think it will hold much water for long... it should dry quickly.
I’ll be sure to update you on any issues.
