Old Apr 21, 2020 | 03:54 PM
  #16461
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by racefan41
Might as well load these for the hell of it
Very good job. I bet those lines are really clean
Old Apr 23, 2020 | 12:57 AM
  #16462
Dean Bean's Avatar
Dean Bean
I was almost certain that i was going to be dropping the transmission after i pulled the pan.. Never had 1 transmission issue in 4 years, i bought a set of rims and tire's from a guy who took them of his 04 Ram. Put the wheels on and parked it. Very next day i had no GO.. PUT IT IN GEAR ,ANY GEAR AND ONLY RESPONSE I GOT WAS FROM THE TROTTLE BODY.. .
Old Apr 23, 2020 | 06:58 AM
  #16463
Wow, that's REALLY bad.......
Old Apr 23, 2020 | 07:58 AM
  #16464
racefan41's Avatar
racefan41
I actually only had a few hard lines and the were at the at the rear of the bed. No lines at the bed rails at all with my diamond plate covering there. Just sprayed up under them. Looking at it now I wished I would have brought the coating around the back of the bed to the taillights. Might hit that part later or paint it black.
Old Apr 23, 2020 | 10:29 AM
  #16465
Donald Stanford's Avatar
Donald Stanford
Default I sold my 2nd gen dodge
Originally Posted by Silver_Dodge
i bought a 2014 dodge 3500 four door 4x4 with the cummins engine,installed a 6" Top Gun Customz suspension lift,new Carli track bar and Carli upper and lower ball joints,new 12.5x37" -18" tires and wheels,had a 6 speed tranny built for strength, installed a new snorkel,yes you can buy a snorkel for your Rams now that is a 2012 and newer,a new smarty touch screen programmer,EGR and particulate filter delete, (the smarty was not used for the delete)now I'm going to build a dump bed on it,the 04 and 05 I built still work great but the 2014,wow,the front bottom of the bed extends under the rear of the cab,it's going to be a challange
Old Apr 23, 2020 | 11:57 AM
  #16466
MoparFanatic21
When I did my Herculiner I did up to the tail lights and the bottom part of the bed (gap between tailgate and bed) just in case lol
Old Apr 24, 2020 | 12:11 PM
  #16467
98Ramboy's Avatar
98Ramboy
I replaced my brake lights and fixed my speakers. Only one more needs to be setup and then I’ll finally have all 4 working again!
Old Apr 25, 2020 | 09:02 PM
  #16468
spyder77's Avatar
spyder77
Today I put a 2020 jump seat in a 2000. No drill needed. I had to use 2 more bolts in holes at rear but everything lined up with holes on bottom of seat and I reused the stock rear cup holders. Had to trim the tray that mounts to the floor in front about an inch on the driver side for the seat mount. The usb inside is unusable but I have a usb and aux line in to replace it on the way. I know my seats suck, but good luck finding a replacement with built in seatbelts for decent price these will be redone when I can.
Old Apr 26, 2020 | 03:54 PM
  #16469
spun360's Avatar
spun360
is that 2020 center still a functional seat when you flip it up?
Old Apr 29, 2020 | 05:19 PM
  #16470
spyder77's Avatar
spyder77
Yep everything lines up great folds up into a seat when needed.
*Today I put a cheap double din in my ram with a kit i got on eBay. Gotta trim alot under the middle vents inside dash and some on the lower part of radio opening had some mounts for the bigger radio and it came with a pigtail for factory harness. I have wanted a double din in my ram forever and didn't want to do fiberglass or some other solution.
Had to trim bezel. They gave me a template to use made it easy to mark and cut.
Add-on bezel clips onto side of big bezel to secure itself and it covers all cuts with plenty of error room.
