Old Apr 8, 2020 | 08:29 AM
  #16441
racefan41's Avatar
racefan41
Can you post pics of that???
I'm having issues posting pics in here, something about the format of my phone pics not compatible. I'll see if I can get it fingered out...
Old Apr 8, 2020 | 08:32 AM
  #16442
Host them somewhere else, then just use image tags and the URL to have them show up here.
Old Apr 8, 2020 | 09:47 AM
  #16443
racefan41's Avatar
racefan41
Cool, I'll give it a shot later today.
Old Apr 8, 2020 | 04:54 PM
  #16444
400Stroker's Avatar
400Stroker
Default 01 RAM 1500 Quad Cab Off Road
Originally Posted by Fox Fader
This is an on going thread.
All you have to do is post what you did to your Ram everyday
and if you did a seperate thread, post a link to it.
Have fun. [sm=smiley20.gif]
repaired the factory CD player
Old Apr 8, 2020 | 09:06 PM
  #16445
racefan41's Avatar
racefan41
In the top left of the picture is where you want to burr it out with a Dremel bit. . It doesn't take much.. The rest of the hole is already there, you just have to grow it that little bit where its shiny.
Old Apr 8, 2020 | 10:15 PM
  #16446
Interesting. Thank You.
Old Apr 11, 2020 | 06:23 PM
  #16447
Spillage's Avatar
Spillage
Haven’t done much for a couple of weeks.
But today I got back to it... I finished the harness for the extra signals the new head unit needs (reverse, p’brake, & camera).
The old setup had pwr, aux, dim, & grnd going from the radio to the pillar gauges... these were hard wired all the way... I had to cut it to get the dash out... so the new one is in two sections with connectors so if the dash ever needs to come out again, it will unplug above the peddles.
These wires and the new ones now neatly join into the adapter harness behind the new unit.
It’s a snug fit, but it does fit... double DIN is in
After a little filing of the opening (it was too small for the unit) the bezel fit.
Considering how it started out, I’m very pleased with it.
And... drumroll...
It works.
The only thing that isn’t right with the new dash/bezel is the headlight switch.
everything else lined up perfectly... my initial thought was I goofed putting the dash frame back together, but on checking, two of the three switch mounting holes are original (not part of the patchwork).
Oh well, something to look at fixing later.
If I feel like it, tomorrow I’ll make a mounting bracket for the backup camera (I have a game plan).
Old Apr 12, 2020 | 12:28 AM
  #16448
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
And... drumroll...
It works.
I mounted mine under the handle. I can get pics if you want. Didn't you piece the day back together? If so, good job! I went with a 9" touch screen and it's doing good! Looks like you used eBay connectors.
Old Apr 12, 2020 | 08:22 AM
  #16449
Spillage's Avatar
Spillage
...Looks like you used eBay connectors.
Yup... and I would not recommend them.
Used “as is”, more times than not you get a dry joint.
To save my investment, I crushed and pushed out a solder ring, then just used them as shrink tube.
Old Apr 12, 2020 | 08:41 AM
  #16450
Spillage's Avatar
Spillage
I mounted mine under the handle. I can get pics if you want...
Yes, I’d be curious to see how you mounted and ran the wires.
I’m going to mount the camera at the top edge of the number plate... although this is a lower vantage point, it will still give me a view with the tailgate down.
And yes, the dash frame behind the new cap and bezel is pieced together and reinforced.
